Thursday
Good Morning,
I've finally got round to checking my Eero 6 5ghz channel. I have some devices that cannot use channel 155 so can I request like others have that this be changed to the lower range please.
Friday
Thanks for confirming. I've raised this over to our Devices Team now and I will post back as soon as we receive an update.
Thursday
Thanks Michelle,
Since it is not possible to temporarily disable the 2.4ghz band to try and force a 5ghz connection, I am unsure which devices may connect via 5ghz. Also, cannot have a separate ssid for 5ghz on Eero 6. It does not help when manufacturers do not state whether their devices can support the higher channel numbers. I know my mobile, TV and Ipad should be able to connect via 5ghz, and my printer is due to replaced shortly which can have 5ghz connectivity.
WiFi Analyser shows 1% use of 5Ghz.
Thursday
Good morning,
I'm sorry to hear this. Would it be possible to confirm which devices won't connect please and I can pass this over to our Devices Team?
