on 04-07-2024 10:06 AM
Good Morning,
I've finally got round to checking my Eero 6 5ghz channel. I have some devices that cannot use channel 155 so can I request like others have that this be changed to the lower range please.
Answered! Go to Solution.
on 26-07-2024 09:54 AM
You can change the password for each channel 2.4ghz/5ghz on the router setup page by:
Enter routerlogin.net or http://192.168.1.1 in the address bar. The router login window displays. Enter the router admin user name and password.
This can isolate the appliances that won't connect to the 5ghz.
on 24-07-2024 06:35 AM
Good morning,
I'm really glad to hear this and thanks for confirming 🙂
on 23-07-2024 02:04 PM
Hi Michelle & Chris,
Just checked with WiFi Analyzer again.
5ghz now on CH 36 (42)
Thank you for your help in this matter
Elgin19
on 23-07-2024 12:36 PM
Hello again,
The team have just come back to me to advise that they have just made another change. Would you mind retesting again please?
on 23-07-2024 12:26 PM
Hi Elgin19,
Michelle has asked me to let you know that it has been passed back to the devices manager. We'll let you know when we have any more information
on 23-07-2024 11:29 AM
Hi Michelle
Just done update to Eero to 7.4.2-15. Eero restarted network.
Have now run WiFi Analyser - still shows as 5ghz as Ch 149 (155)
on 23-07-2024 10:45 AM
on 09-07-2024 12:54 PM
Just to add to this, I've also chased this for an update with our Devices Manager.
on 09-07-2024 12:53 PM
The simple way to find out which devices are connected to the 5GHz band is to use the eero app. From there go to Home & tap the device in question, it will tell you which eero it is connected to (if you have more than one) as well as which band (Connection section).
on 05-07-2024 06:33 AM
Thanks for confirming. I've raised this over to our Devices Team now and I will post back as soon as we receive an update.
on 04-07-2024 02:29 PM
Thanks Michelle,
Since it is not possible to temporarily disable the 2.4ghz band to try and force a 5ghz connection, I am unsure which devices may connect via 5ghz. Also, cannot have a separate ssid for 5ghz on Eero 6. It does not help when manufacturers do not state whether their devices can support the higher channel numbers. I know my mobile, TV and Ipad should be able to connect via 5ghz, and my printer is due to replaced shortly which can have 5ghz connectivity.
WiFi Analyser shows 1% use of 5Ghz.
on 04-07-2024 10:10 AM
Good morning,
I'm sorry to hear this. Would it be possible to confirm which devices won't connect please and I can pass this over to our Devices Team?
