on 14-01-2024 04:28 PM
We have Full Fibre 900, since just after Christmas. Never more than 640mbps so far. Unable to check connection. What to do?
on 27-01-2024 03:03 PM
Hi @ekcooke
It does not mean though, that the devices you have cannot work faster. What is the network adapter you are using in your laptop and what are your phones? I will Google them to see for you.
on 27-01-2024 02:24 PM
Thank you. I think that explains it. Even though we don't use 'hungry' services, just a laptop and a couple of mobile phones, I can now understand what affects the speed reports.
on 26-01-2024 09:44 AM
To answer your question @ekcooke, I would say that the speed shown in the Eero app is the speed of your full fibre service at the router, whereas the speed tests on the devices are affected by the link rate from that device to the Eero, out over the Eero/fibre connection to the internet. If the device is running a slower link rate than the speed of the fibre, then you will get a slower speed test on that device.
When you have speeds as high as the 900M service, it could very easily be the case that the device is using an older WiFi adapter that can't run at those sorts of speeds. Even some older wired Ethernet adapters might only run at 100M and therefore you'll never get 900M on such a device.
With WiFi, this can be even more affected by WiFi interference reducing the device's link speed to the Eero.
Please can you check the WiFi specifications of your devices & let me know what they are? If the device displays the link rate, then that is even better. If you don't know how to find this information, then let me know what some of the devices are & I will look them up, when I get the time.
on 26-01-2024 09:15 AM
Hi ekcooke,
The main point of Full Fibre 900 isn't really that you get 900Mbps on one device, it's more that there's enough bandwidth to run multiple devices at the same time without any loss of performance. For instance someone in a household could be streaming Netflix on the TV, while someone else is watching YouTube videos, and someone else streaming spotify or downloading a file. It just means there's enough bandwidth to meet a households needs. The Eero is showing that you have the bandwidth available even if you aren't getting that speed on one specific device
on 25-01-2024 07:18 PM
EERO app speed check shows around 940-960mbps, so I am told the service is correct. However, every other broadband speed checker says I am getting between 540 and 740.
What makes the EERO check right, and all the others wrong?
Overall the connec tion seems ok, but I want assurance I am getting what I pay for.....
on 25-01-2024 07:04 AM
What speeds do the eero speed checker show please? How has the overall performance of the connection been?
on 24-01-2024 04:48 PM
Last update from TalkTalk states we must only use the EERO app to check speeds. When I do that the speeds are as contracted, but all other (non EERO) checkers show speeds between 540 and 740mbps.
Am I to believe the EERO speed is correct and all other checkers are wrong?
on 16-01-2024 07:14 AM
Good morning,
I've posted on your other topic this morning. Just to confirm, did you try powering down the ONT and eero to see how the speeds compare?
on 15-01-2024 04:02 PM
Thanks for that @ekcooke, please could you try turning the ONT & Eero off for at least 30 mins & then recheck it?
on 15-01-2024 03:59 PM
I have a feeling @ekcooke that as you have the Eero, there might be somewhere in the Eero app that tells you the speed the fibre is currently running at. I do not have the Eero myself, so cannot tell you where that is. This might save you from trying to connect something up to the ONT.
Current speed check -
Connection check still showing "
We tried to test your network connection but we can’t provide status updates on your current package.
If you need any additional help, chat to one of our team...."
on 15-01-2024 03:56 PM
Do you have any other wired (Ethernet) devices that you can do a speed test from that you could connect to the router end of this cable?
on 15-01-2024 03:51 PM
I don't have a connector to link that cable to my laptop......
on 15-01-2024 03:05 PM
Just unplug the cable at the router end that connects to the ONT & connect it to a laptop or similar. Then try a speed test from there.
on 15-01-2024 01:57 PM
Having identified the ONT, how do I connect to it directly?
on 15-01-2024 11:47 AM
The staff here will not call you. The router is connected to another box on the wall called an ONT (Optical Network Termination), it might be white or black and will have some lights on it.
on 15-01-2024 11:31 AM
Maybe best if Michelle calls?
on 15-01-2024 11:30 AM
Sorry, not techie enough to understand!!! What is an ONT?
I have a black box with 'Grandstream' on - the blue telephone image is flashing slowly
I have a white EERO box with just a steady white light
on 15-01-2024 07:38 AM
How are you getting on? What speeds are you seeing if you run a wired speed test directly at the ONT with the router/eero removed please?
on 14-01-2024 09:48 PM
Can you connect a wired (Ethernet) device in place of your router to the Ethernet cable coming out of your ONT? Then do a speed test from there? What speeds do you get there?
