Speed Fluctuations
KatKiller
Message 8 of 8
I'm on FIbre 150, apparently, but having done lots of speed tests since the upgrade i seem to be getting a LOT of drops down to way below half of that. i read that it would take time to "bed in", but how long is that supposed to be?
7 REPLIES 7
Message 1 of 8
Hi @KatKiller
Which make/model of router are you using?
In other words, I offer a free, impartial analysis of your Wi-Fi network and will try to help you optimise your Wi-Fi connection. The next stage involves sending out a guide to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
The information below is provided by TalkTalk. For confirmation, please contact @Lorrainef.
If you need further help or if we need to take any details such as personal information about your account like phone numbers, account numbers, etc, one of the TalkTalk team will jump in and help out.
Message 2 of 8
Power cuts / surges can sometimes affect the router, @KatKiller.
Mine went funny after a surge when a lightning bolt hit nearby!
Let us know how you get on after the 30 minute switch off.
My own router needed replacing.
Message 3 of 8
Try turning the ONT and eero off for minimum 30 minutes
Message 4 of 8
seems it's the wifi, just tested here on ether and it's fine. router hasn't moved etc, don't know why it should be so radically bad. we did have a power cut last night apparently but i don't see that that would be a cause of anything.
Message 5 of 8
Forum staff on the community don't work here at weekends, @KatKiller.
For more immediate support use phone or Chat:
KatKiller
Message 6 of 8
wifi's down to 7.2Mps right now. even my router home is taking ages to load.
Message 7 of 8
No, "bedding in" is a term generally used for mechanical components, not internet connections. While some internet providers might experience temporary speed fluctuations during the initial setup or connection process, this is not the same as bedding in. Fibre 150 typically delivers consistent speeds right from the start.
Elaboration:
  • No "Bedding In" Needed:
    The idea of a "bedding in" period for internet connections is a misnomer. Fibre 150, like most modern internet technologies, should provide the advertised speeds from the moment it's activated.
  • Initial Fluctuations:
    Some providers might mention temporary speed variations, especially in the first few days, but this is due to things like network setup or brief connection issues, not a "bedding in" process.
  • Consistent Performance:
    Fibre 150 is designed to offer consistent and reliable speeds, allowing users to stream, game, and download without interruption.
  • Technical Considerations:
    While the physical installation of fibre optic cable can sometimes have minor initial issues, the connection itself should be stable and reliable after the initial setup.
