Total Home WiFi
Jeggers
Message 43 of 43
A Full Fibre 150 upgrade was installed at my home one week ago incorporating a single Eero router but with subsequent mixed speed results at both router position and workstation positions - two devices much improved and two devices hardly improved from previous Fibre 65 installation.
TalkTalk technicians have made several attempts to improved the installation but with little success and are suggesting an upgrading to Total Home WiFi.
What is not clear to me is whether such upgrade, having two additional Eero units sited at workstations, will give me, at best, simply the same ratings as currently received at the incoming router location or do they somehow boost the signal reaching the workstations to give me nearer to what I was expecting on all devices.
Put another way, would I be wasting my money on upgrading wifi as opposed to buying some newer devices?
More generally, is Total Home WiFi a successful and useful upgrade?
Any advice will be appreciated.
Geoff.
42 REPLIES 42
Jeggers
Message 41 of 43
Many thanks for your prompt reply and I would appreciate access to the guide mentioned in due course.
What I meant with regard to the devices is that, directly in front of the Eero router, an Acer tablet and a Xiaomi Redmi Note mobile phone receive speeds in excess of 150Mbps and also both achieve those speeds at workstations some 8 metres from the router. However, a Lenovo laptop and a Samsung Galaxy A20E each register only around 30-35Mbps in front of the router and around-30Mbps at the relevant workstations given above. All above devices have WiFi 4 standards 802.11n or 802.11a/b/g/n whatever that means as I have only limited tech knowledge. The Eero appears to work fine with some devices but not with others which suggests that the the problem may be with those devices?
I look forward to you response.
Geoff.
Message 42 of 43
I am not sure what you mean by:-
"two devices much improved and two devices hardly improved from previous Fibre 65 installation"  ?
However, I would not spend any money at all, without first investigating the root cause of the problem. This is an area where I can help a lot.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Whilst the Eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional Eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
