on 22-01-2024 05:38 PM
City fibre came and installed our fibre box this morning and left when 4 green lights came on - they tested and checked everything and said it was working fine. They connected the eero 6 and we downloaded the eero app. I've followed the instructions and the app on my phone can find the Eero, but fails during set up and says eero can’t connect to the internet. There is an exclamation mark next to WAN IP address. I've called Eero who said it's not an issue there end as the router is working fine. The engineers kindly came and gave us a standard TalkTalk router and that's not working either. Spoke to 3 different people at TalkTalk who all claim there's an error on the line but the engineers have confirmed it was all working fine.
I've already missed a day of work due to this, can anyone help? I'm desperate.
29-01-2024 12:26 PM - edited 29-01-2024 12:30 PM
@MissLucinda99997, compensation is calculated once the issue has been resolved and doesn't include the initial couple of days, in order to give reasonable time for resolution.
It's generous per day, in order to cover the extra costs and inconvenience.
It takes up to 30 days to show.
See full details here:
https://community.talktalk.co.uk/t5/Articles/About-your-auto-compensation-credit/ta-p/2326583
See also Talktalk's Ts&Cs, linked at the foot of the page.
on 29-01-2024 12:13 PM
I had to spent over £50 on data to ensure I didn't lose my job so I fully intend to get compensated! Thank you 🙂
on 29-01-2024 11:35 AM
Make sure you get the compensation for each day with no Internet.
on 29-01-2024 09:49 AM
Good morning,
Thanks for confirming and I'm sorry that it has taken a while to resolve this for you. Please let us know if you do need any further assistance.
on 29-01-2024 09:48 AM
Heya,
I had to spend a lot of Friday turning the box on and off and then finally it started working! Thank you for your help
on 29-01-2024 07:57 AM
Just checking back in to confirm if this is now working for you?
on 26-01-2024 12:38 PM
I'm sorry to hear this. The team said that as the profile has been changed, could you now try powering down the ONT and the router for a full 30 minutes and then let us know if it does then connect please?
on 26-01-2024 12:35 PM
Still nothing. Seeing the exact same error message I was Monday.
And I was told I'd be contacted 12-2 yesterday by a case manager, they didn't call so I called them, told it has been changed 4-6 (without informing me) but I'd only actually get called if they resolved the issue so of course no one called. Call today asking what on earth this sort of service is as I have now had no Internet for over a week and told now I can't expect to hear anything until 4-6 on Monday!!!! So no internet all weekend? This is absolutely horrific.
on 26-01-2024 11:38 AM
Our team have confirmed that a profile change has been completed and have asked if you can confirm if you currently have the wifi hub 2 connected at the moment? Are you now able to connect please?
on 25-01-2024 06:51 AM
I'm really sorry, I will chase the team for an update now.
on 24-01-2024 06:14 PM
I researched myself because no one seemed to be able to find an answer and told the support team to check if they'd filled my profile with cityfibre out correctly and they said actually it needed a modification but would be fixed within 24 hours.... that was 10am yesterday and when I chased they've said it could be up to 48 hours longer. This is insane.
on 23-01-2024 12:07 PM
I'm sorry to hear this. I've passed this over to our Faults Escalation Team now and will post back as soon as I receive an update. It's possible that the team may try and contact you directly.
on 23-01-2024 11:57 AM
Everything is still showing as 'connected without internet' unfortunately
23-01-2024 10:27 AM - edited 23-01-2024 10:29 AM
Thanks - no it shouldn't affect the speed
on 23-01-2024 10:15 AM
Thanks Chris I'll wait 30 minutes then try the talktalk router. Will using this instead if Eeros affect the speed at all?
on 23-01-2024 10:13 AM
5464 is the model of router. Sorry, I've checked a 5464 that we have here and the firmware version isn't on the label. I'm going to make a change to the connection settings which will hopefully allow the TalkTalk router to connect. I'll do this now, can you give it 30 minutes then try the TalkTalk router again
on 23-01-2024 10:06 AM
We were given an Eeros device for this - can't see a firmware label on there?
The engineers did also give us a talktalk router to try when it didn't work which uses the firmware 5464-2 . Neither option will connect to the internet
on 23-01-2024 10:00 AM
Could you have a look on the back of the TalkTalk router and tell me what the firmware version is, it should be on the label, I just need the last 5 characters
on 23-01-2024 09:57 AM
All 4 are green and the Ethernet one flickers.
on 23-01-2024 09:56 AM
OK thanks. Which lights are currently on, on the ONT?
