What is EERO?
on 06-10-2024 06:06 PM
Message 64 of 67
As part of my new fibre connection, or of the random boxes I've received appread to be called "EERO". There is not explanation as to what it is or what it's for. The instructions say:
Step 1: download the app.
No. No. No. No. are you completely insane? Tell me what it is and what it does, then I'll decide IF I want to plug it in to my network or download any app.
NB, again, I am OBLIGED to put a "label" on my post. EEPRO is not one of the options. What should I do? this is soooo random. Is this damn thing even from TalkTalk?
Labels:
- Labels:
Connection
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
66 REPLIES 66
on 06-10-2024 06:27 PM
Message 61 of 67
That's nice. So, when do I receive my mobile phone, or other device which can run an "app"?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-10-2024 06:25 PM
Message 62 of 67
I'm getting a new fibre service. I have received three random boxes.
One is called EERO (I guess it's the router, but there are ZERO instructions other than "download the app" which is NOT going to happen until someone tells me what the box is.
One has no name, but it has an HDMI connector, so I guess it's the set top box. It's instructions say "disconnect you aerial cable and connect it to the hub". That's not goig to happen, because then how can I receive live terrestrial TV?
Finally, there's a "Digital Voice Adapter" which, I think, (based on 25 years of industrial experience) is probably a VoIP adapter, but I'm waiting for a straight answer.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
06-10-2024 06:10 PM - edited 06-10-2024 06:11 PM
Message 63 of 67
It is your new router.
It is controlled via an app instead of using an interface on your web browser.
Details can be found here
https://www.talktalk.co.uk/broadband/wifi-hub/eero
I use one, with no problems
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 17-06-2024 07:00 AM
Message 65 of 67
How are you getting on? Did you try factory resetting the router?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 16-06-2024 10:51 PM
Message 66 of 67
Have you tried doing a factory reset of the router?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 16-06-2024 04:03 PM
Message 67 of 67
My Sagemcom FAST router is very slow. I don't mean the WiFi is slow. The web interface is dreadfully slow, and some portions don't work. It takes many seconds for the web GUI to refresh. Once I'm in "Manage Advanced Settings" then TalkTalk WiFi Hub, I see the Device Info / General tab, but selecting Light Control, DNS, DynDNS, or Maintenance does nothing. The tabs no longer appear.
I was actually looking for an option to disable beamforming, since there is a large number of WiFi clients connected and some don't stay connected reliably.
Can you help, please?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- « Previous
- Next »
