WiFi Booster
Chessewax
Message 25 of 25
I would like to get a work signal booster the second floor of my house is getting such a weak signal and considering we’ve bought a very good expensive package I don’t think this is very acceptable.
C.Steele
24 REPLIES 24
Message 1 of 25
Hi @BRYANQUINTRELL
How can we help you? You will need to create your own thread first.
Message 2 of 25
@BRYANQUINTRELL
Hello! Not sure what your point/question is, but if you would like help then please start your own topic.
Message 3 of 25
AC1750DUAL BANDTPLINK MESH WIFI EXTENDER  IS IT COMPATIBLE WITH  MY TALKTALK ROUTER
Message 4 of 25
Hi @Chessewax
I'm just sending you a Private Message.
Message 5 of 25
Hi Debbie, I don’t suppose there’s any tracking details on the booster is there please. Just so we can plan to be in when it comes.
kind regards
C.Steele
Message 6 of 25
Hi @Chessewax
You're welcome 🙂
Message 7 of 25
Amazing, thank you very much for all your support.
C.Steele
Message 8 of 25
Morning @Chessewax
You should receive the eero within the next 72hrs.
DJI_MINI_2_SE
Whizz Kid
Message 10 of 25
Brilliant, thanks a lot for your help
C.Steele
Message 11 of 25
Hi @Chessewax
Thank you. I've asked our order management team to order the eero for you.
I will post back here to confirm once the eero has been ordered.
Message 12 of 25
Should all be completed now 😀
C.Steele
Message 13 of 25
Hi @Chessewax
Please can you add your name and TalkTalk account number to your Community Profile, I can then send the additional eero for you.
Debbie 🙂
Message 14 of 25
Brilliant that would be perfect if we could arrange one to be sent out please. Hopefully will fix the connection issue
C.Steele
Message 15 of 25
You just need a mains socket for it, Whilst Ethernet can be used, the normal connection between the eeros is over WiFi.
Message 16 of 25
would this need to be plugged into an Ethernet port as the only one we have is downstairs. We ideally need one that just needs plugging into a wall socket?
C.Steele
Message 18 of 25
@Chessewax
I thought that FF 900 got two eero Pro 6s, not the one. Either way @Debbie-TalkTalk is going to sort it for you.
Message 19 of 25
Hi @Chessewax
Apologies for this.
I can send you an additional eero, are you happy for me to arrange this?
Message 20 of 25
Just the One we were supplied with it’s perfect fine in the room the router is however the room upstairs directly above it the signal is terrible.
openreach installed it.
C.Steele
Anonymous User
