WiFi dropping out
nikola77
Message 18 of 18
Hi there. Can anyone help me.
 last time I had WiFi connection issue. Apparently it was fix however after few weeks problem start again. My WiFi it’s dropping multiple times throughout the day. I did full reset on my router. But it didn’t help. The light it’s steady white even when connection it’s dropping. I need to switch off the router completely to get my connection back then it’s flashing orange and it’s change to steady white.
17 REPLIES 17
Message 1 of 18
Hi @nikola77
Message 2 of 18
Hi @Debbie-TalkTalk
Okey let’s try it.
Message 3 of 18
Hi nikola77
This should not be related to the issue reported back in December as a fix was rolled out to resolve this issue.
I think it's best we replace the router again first, are you still happy for me to go ahead and order a router for testing?
Message 4 of 18
Hi @Debbie-TalkTalk
I would say like 10 times maybe connection usually last for 30 min or so.
Message 5 of 18
Hi @nikola77
I can see a high number of re connections on the line. How often are you rebooting the router? (daily)
Message 6 of 18
Hi @nikola77
Thanks for your reply. Let me just run some more tests now and I will post back shortly.
Message 7 of 18
Hi @KeithFrench
Both of connections dropping out.
Message 8 of 18
Hi @nikola77
@Debbie-TalkTalk has asked me to help you with WiFi issues, but I see in an earlier post, that it was affecting wired (Ethernet) connections as well. Is that still the case or is it wireless only that is the issue?
Message 9 of 18
Hi @nikola77
Sorry another question, do you have any wired devices connected?
Message 10 of 18
I got it in mid December. As far I can remember the was some issue with software. I know engineers fix that and the connection was stable for like 3-4 weeks.
Message 11 of 18
Hi @nikola77
When did you last receive a replacement router?
Once of our Community Stars @KeithFrench offers really good advice on improving WIFI performance. Would you like Keith to take a look?
Message 12 of 18
Hi @Debbie-TalkTalk
We can try. However last time when the issue occurred I got replacement router and the issue was still there.
Message 13 of 18
Hi @nikola77
Thanks for confirming this. Would you like me to send a replacement router for testing so we can rule this out?
Message 14 of 18
Hi @Chris-TalkTalk
I did like you said and WiFi it’s still dropping out.
Message 15 of 18
Hi nikola77,
Could you switch the router off and leave it off for at least 30 minutes, then switch back on and retest. Please let us know how you get on
Message 16 of 18
Hi @Debbie-TalkTalk
Yes WiFi and wired connection it’s dropping.
Message 17 of 18
Hi @nikola77
The line tests are clear. Can I just check, do you have any wired connections? Are wired connections also dropping?
