YALE alarms do not work with Eero
on 21-01-2025 05:55 PM
Message 53 of 53
My Yale HSA 6610 alarm worked perfectly for years until I installed Full Fibre 500 with an Eero router a few days ago. I have spent hours with Talktalk customer care and web chat who seem oblivious to the problem and Yale are adament that it is due to the Eero router. I have followed all the advice including changing the DNS to 8.8.8.8 and 8.8.4.4. I have opened the ports 5222 and 8765. I have tried Legacy mode even though it is an ethernet connection not a WIFI connection to the alarm hub. I have reset the Eero, I have reset the alarm hub.
It's incredibly frustrating as well as annoying. Why isn't there a fix for this. It has been going on for years and Yale say it is a compatibility issue which can be overcome. I feel letdown by talktalk.
Labels:
- Labels:
Connection
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
52 REPLIES 52
on 11-02-2025 05:58 PM
Message 1 of 53
Just one last update , maybe to help other Yale alarm users in future.
So I finally got my Yale alarm system working. In spite of all the changes in settings and testing both the Eero router as well as the Yale hub, I still couldn't get any key fob or keypad to set the alarm even though the Yale hub was connected and showing a green light.
I decided it must be a radio frequency issue ( all the devices are linked by radio frequency not WIFI or Ethernet. The ethernet connection means that the alarm can also be controlled by the Yale app. But disconnecting it , will still leave the alarm working using radio frequency)
I discovered that although I had 18 devices on the app, none of them were paired. When I paired a new spare PIR, all the other devices disappeared from my list in the Yale app. Although they were supposedly paired, in reality they were not explaining why nothing worked. I proceeded to pair all the other devices and now everything is working including notifications.
I can't explain why this happened when I upgraded to Fast fibre with the Eero but it did and the solution was straightforward ( still needed the settings set to the Yale recommendations)
I am amazed nobody at Yale suggested it.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 03-02-2025 09:12 AM
Message 2 of 53
You are welcome @STEPHENMAK, I must be honest as the eero showed it as connected I thought that this could be the Yale that was at fault. However, occasions like this are difficult for me to be 100% sure, as I do not have one of these alarms.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 03-02-2025 07:57 AM
Message 3 of 53
Hi STEPHEN,
Thanks for the update and I'm sorry to hear this. Please let us know how you get on.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 03-02-2025 07:48 AM
Message 4 of 53
I tried the new Eero router without any difference, so the Yale alarm is still not working.
On Saturday I had a long conversation with Eero Technical help who have come across this problem before and are aware of it. They tried a few more things . They switched off the IPv6 and restarted the router without any success. They checked all the other settings and said all the Yale recommended settings were correct. They said there was nothing more that they could suggest.
Today I am sending the Yale Alarm hub to Yale who are going to test it. If it they find that it works, they will send it back. If it is faulty , they will replace it as a gesture of good will. As the alarm worked on the morning that the Fibre 500 was installed 2 weeks ago, I am not hopefull that they will find any fault with the Alarm hub.
So unfortunately, it looks like I will have to change a relatively new alarm system which is still being sold by Yale.
Thanks to everyone here who tried to sort this out for me. It will be interesting to see if this crops up again in the coming months as more and more people move to full fibre with the Eero router.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 03-02-2025 06:33 AM
Message 5 of 53
Hi STEPHEN,
How are you getting on?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-01-2025 12:46 PM
Message 6 of 53
Great thank you 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-01-2025 12:14 PM
Message 7 of 53
Thanks, Will try this later and tell you how everything went.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-01-2025 11:51 AM
Message 8 of 53
Hi @STEPHENMAK
To replace the possibly faulty eero with another, in the app go to:-
From the Home tab tap the blue + icon at the top right, then tap Add or replace eero devices.
From the next page, tap Replace eero Device and follow the prompts.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
28-01-2025 02:12 PM - edited 28-01-2025 02:12 PM
Message 9 of 53
Please disregard this email as it was sent in error. The replacement eero will not be chargeable.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-01-2025 02:08 PM
Message 10 of 53
Hi, Thanks but why have I got an email saying that I am being charged £129 for this replacement Eero ??
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-01-2025 01:51 PM
Message 11 of 53
Hi @STEPHENMAK
The replacement eero is on its way, please allow 24-48hrs for this to arrive.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-01-2025 01:40 PM
Message 12 of 53
I spoke to Yale this morning and they tried a few more things which didn't work. They have said that they have recently come across 2 cases where the Eero was at fault so it would help eliminate this as a cause of all the problems. So yes , please could you send out another Eero ASAP.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-01-2025 01:22 PM
Message 13 of 53
Thanks @KeithFrench
@STEPHENMAK Are you happy for us to send a replacement eero for testing purposes?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-01-2025 01:14 PM
Message 14 of 53
Hi @Anonymous
After working for some time on this, it looks as if there might be a problem with this eero. Please could you replace this Pro 6 to rule out any hardware issue?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-01-2025 01:17 PM
Message 15 of 53
I have now tested the port forwarding on the eero that is required for Yale & it worked fine.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-01-2025 12:09 PM
Message 16 of 53
I will get in touch with Yale. The Eero app is saying the Yale hub is connected with the ethernet cable and indeed the green light is on. In the manual, it says that this means it is linked to the Server/Internet.
However, nothing works with the Alarm, I will contact Yale again later today.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-01-2025 09:50 AM
Message 17 of 53
Hi @STEPHENMAK
From your description, the green light signifies it is connected. However, does this mean it is just connected to the eero or some Yale system online? Please can you confirm, or ask Yale support?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-01-2025 08:03 AM
Message 18 of 53
I'm sorry for the delay. Thank you, I've raised this to our Devices Team and will post back as soon as I have an update for you.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-01-2025 11:00 PM
Message 19 of 53
I have a green light , no orange light and no working alarm. This is exactly the situation I had a couple of days ago.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-01-2025 10:56 PM
Message 20 of 53
There is no orange light now.There is no connection with the app. It's all the same as before.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- Poor Full Fibre Downstream and Upstream in Full Fibre
- New EERO sent with Digital VOIP box not working in Home Phone
- Eero router does not have discovery/secure plus in Full Fibre
- Port forwarding minecraft server in Broadband
- Facetime calls not connecting / going through when connected to EERO in Fibre
