Yale smart alarm offline
amos19
Message 50 of 50
Hi just gone on to fiber had new eero modem my yale smart alarm worked for couple of hours, then the modem done a update now the alarm is offline and i cant reconnect i tried rebooting the alarm and modem but us still off line, any advice or suggestion's would be great, Thanks
49 REPLIES 49
Message 21 of 50
Just hope you update doesn't affect it
Message 22 of 50
Great, at least that is sorted. I think the current version is V7.8, but maybe you won't get that until after you do this update. I have noticed any problems.
Message 23 of 50
Good morning Keith,
Just setup new eero pro and all is working good alarm works bit worried about when it up dates its says update available
Amos
Message 24 of 50
Yes the cable are good its the same one i used in work and tried different one as well at home im hoping maybe the new eero pro will work tomorrow, i think its just conflict between eero/TT and yale and hopefully they will fix bug without admitting who's fault it is
Message 25 of 50
Hi @amos19
I have now connected a laptop to each Ethernet port on my extender and that shows as online & works fine as well.
I don't believe, therefore, that this can be related to the eero update. We know that the Ethernet port on the Yale is fine, as it worked OK when you were at work. This makes me think that either the Ethernet port on your eero is faulty (unlikely, but possible) or, far more likely, the problem is the Ethernet cable. I know that you said that you have tried two different cables, but are you 100% confident that they are fully inserted at either end? This might sound daft, but some Ethernet cables have a plastic shroud around the release lever and these can sometimes prevent the cable from pushing all the way into the connector.
Message 26 of 50
I have just connected my PC via Ethernet rather than WiFi & it shows up online & works fine. This is connected to one Ethernet port on my extender eero mesh node, I have also tried the other port & that connects fine as well. Downstairs in the gateway node, I have the Grandstream connected to the spare Ethernet port & that is online OK.
Message 27 of 50
i havent tried yet only today i had them so going to try in morning when i got piece at home
Message 28 of 50
also at moment its disconnected because the bleeping
Message 29 of 50
What happens if you put the replacement eero on?
Message 30 of 50
I have tried 2 cables still same and yale connected through 4  splitter and direct to the eero but same outcome
Message 31 of 50
Hi @amos19
Now we're getting somewhere. Both the eero Pro 6 & the eero 6 have the same number of Ethernet ports, but when one is an extender that allows you to use the two ports of the extender eero, in addition to the one spare on the gateway eero.
How is the Ethernet cable from the Yale currently connected to the eero, directly via the one spare Ethernet port or is it via a network switch? Have you tried a new Ethernet cable? I do have another thread on the go, where not all of that customer's Ethernet-connected devices show online. However, I am waiting on that person carrying out some more diagnostics.
Message 32 of 50
No says offline, i have had new eero6 pro from TT as the eero6 doesn't have the ports i need to they said i could use one as booster so going to try the pro as main but cant till tomorrow
Message 33 of 50
Can you please answer a question in my last post? In the eero app, does the Yale show as a connected device when connected via Ethernet cable?
Message 34 of 50
I will message them now dont think i will get reply over weekend, I took the yale hub to work this morning and connected it to the broadband there as its not fiber and it worked correctly straightway with no issues just so frustrating. Thank you for your help so far
Message 35 of 50
I have no idea about how you find the IP address, this is the one that your Yale alarm communicates to the Yale servers on. I appreciate that you don't know about the double bleep, which is why I keep asking you to contact Yale Support to find out.
I am sure we must have checked this before, but does the Yale shows as a connected device in the eero app?
Message 36 of 50
Hi i cant find anything for the double bleep dont know what is trying to say? the ip addres you need where will i find this.
This is the manual for the alarms
SR_Alarm_Manual_A5-2018-V2A.pdf
Message 37 of 50
That link doesn't help, as when I go to the support & downloads section, I still need to know the model number:-
https://yalehome.co.uk/support/download-center/product-manuals/smart-alarms
TalkTalk do not block ports in the outbound direction, so that shouldn't be the issue. However, to prove this, I need to know the IP address or domain name that the alarm uses to communicate with the Yale system. Please, can you find this out, then I can test it.
You still haven't told me what these bleeps signify. I do not have this device, so unless you tell me, I do not have much to go on.
Message 38 of 50
Like said before once ethernet cable is in there are no lights just double bleeps closesd think i can find for my Yale smart sr hub is this link
yalehome.co.uk/support/product-support/support-for-sr-smart-home-alarm
I have contacted yale and this is what they said
Please turn the Yale hub off from the main power and the backup battery (Behind the hub under the rubber cover is a slider switch for the backup battery - remove the rubber cover and get a pen to slide the slider switch to off) then reboot your home router once rebooted power the Yale hub back on from main power and the backup battery and try port 1 in your router for it. If the hub does still not come back online speak to your network provider to make sure ports 80 and 81 are not blocked you can also change you DNS settings with your network provider to 8.8.8.8 and this may help resolve your issue.
and this
The hub is not faulty it is an issue with the alarm hub connecting to your new router which you will have to speak to your network provider to fix.
Message 39 of 50
Hi @amos19
A video is of no use. I requested a link to the correct alarm on the Yale website so that I can download a user guide.
To try and save time, in addition to this, I need to know, as I asked before:-
  • With the Ethernet cable connected, is the top light green?
  • What state is the fault status light in the middle?
Can you please contact Yale support & find this information for me? Without it, I can't begin to investigate this problem. Just saying that it is the fault of the eero gives me nothing to go on.
Message 40 of 50
No i dont have the sync same as the one in the link its smart hub 2.0
https://www.bing.com/videos/riverview/relatedvideo?q=yale+smart+smart+hub&mid=3649DB110BC73C14DB6236...
