on 28-05-2024 07:24 PM
Checking 'my devices' it says this about our TV. What does this mean? Is it just a poor wifi connection, or does it indicate anything more? The TV is only about 20' from the router, although there are a couple of walls in the way.
Perhaps this is related to the fact that I cannot seem to set up 5GHz Wifi on the router? The router says it's on and visible, but none of my devices can see it.
on 04-06-2024 10:55 AM
I would not rely on that part of the MyConnection website as there are some issues with it.
However, looking at what it says, I do think that WiFi interference, or simply optimising your WiFi network should be done.
I will PM you a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it. Collect the screenshots that I require and include them in your reply. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
on 03-06-2024 08:48 PM
Yes, I know how to see devices on the router. I was talking about on the TalkTalk website. That's where the latency message came from. I just checked and now I seem to have more issues than before:
I have no idea what 3 of these are. It's possible that they are my son and wife's devices when they visited us a couple of times.
Please do send me your guide, as I hope it can help sort these issues. Note that I have read the TalkTalk top tips and these are already done (like up to date software), impossible to improve (like the router position), or impractical (like disconnecting devices - does anybody do this?).
on 03-06-2024 01:34 PM
If you just want to update the devices shown on the router, you can easily do that yourself. Just go into Manage advanced settings on the router & a list of your currently connected devices will be seen. Click on each one & set a friendly name & update the icon as required.
Would you like me to send you my guide on dealing with WiFi interference & optimising your WiFi?
on 03-06-2024 12:03 PM
I rather suspected that to be the case. Hopefully moving several other devices to 5Ghz will enable the TV to get more bandwidth? How soon can I expect "my devices" to update, so I can see?
I guess that the only alternative is to get some sort of booster?
on 03-06-2024 10:29 AM
From what I can find out it is 2.4GHz only, working up to 802.11n, so that would account for it not detecting the 5GHz band.
on 03-06-2024 06:05 AM
The manual says it's a Samsung UHD 7 series. It's about 5 years old.
on 02-06-2024 09:52 PM
Channel 36 is fine. What make/model of TV is it & I will see what I can find out?
on 02-06-2024 07:32 PM
It's using channel 36. It just defaulted to that.
P.S. The TV cannot see the 5GHz, so I guess it's not compatible.
on 02-06-2024 02:55 PM
The 5364 will broadcast a hidden network from time to time and you will not be able to connect to that. The purpose of the hidden network is for when it is used in conjunction with the Sagemcom FAST266, which turns the router & 266 into a mesh network. What WiFi channel is your 5GHz band now using?
01-06-2024 03:38 PM - edited 01-06-2024 07:41 PM
OK, I've reset and then I renamed the 5GHz SSID, but it still didn't show up. However, when I put in the new name and password into Other Wifi it told me that I was accessing a "Hidden Network". It definitely works and is noticeably faster - but why is it hidden?
I was able to connect my Surface Pro with no problem to 5Ghz, but my Echo Studio doesn't want to know, as yet.
The 'hidden' seems to have disappeared, so I guess it is working. I'll update on the TV situation when I change that.
on 31-05-2024 09:54 PM
Been busy, will do it tomorrow. Want a bit of time as will have to reconnect a lot of things, like Hives, Echoes, Ovens, TV, etc. etc.
on 31-05-2024 07:24 AM
Hi ThortheMerciless,
How are you getting on?
on 30-05-2024 07:43 AM
We'll check back in with you tomorrow to see how you're getting on.
29-05-2024 01:56 PM - edited 29-05-2024 01:57 PM
I've hardly touched it apart from changing the name of the 5GHz so it was one digit different from the 2.4GHz. So hopefully it won't need anything doing.
Out for the rest of today, so will give it a go tomorrow.
P.S. I see that this problem has been known about for over a year. Surely there should have been a firmware update by now?
on 29-05-2024 01:38 PM
When you reset it, it will connect to the internet OK. However, anything that you have changed subsequently will need to be re-entered by yourself. This might include:-
Beyond that, it is impossible to know what you have set up previously. However, I will help you with anything that you are unsure of when it comes to re-configuring the router.
29-05-2024 01:22 PM - edited 29-05-2024 01:35 PM
No, I never touched it until I was looking at why the WiFi was problematical. Now I understand the naming scheme, based on the back it is a FAST 5364-3. TB
So if I do a factory reset, do I need to do anything afterwards to get it running again? Do I need to note anything down before the reset?
P.S. I had a quick look at posts on the bug, but mine is shown as ON and UP.
I also notice that the 2.4GHz is set at 802.11b+g+2 and 20MHz, while the 5GHz is 802.11a+n+ac and 80MHz
on 29-05-2024 08:45 AM
Ok thanks for the info, you have either the Sagemcom FAST5364 or 5464.
Have you disabled the 5GHz band temporarily at all? There is a bug in this firmware that if you have, on re-enabling it, it will no longer work correctly. The only workaround is to do a factory reset on the router. Even if you have not disabled it, this would be the next logical step to perform.
on 29-05-2024 12:47 AM
Not sure how I tell the make/model of the TalkTalk Router, but inside the WiFi-Hub it says, "TalkTalk Wi-Fi Hub
version SG4K100174". Below is a screenshot of what the WiFi shows, but none of my devices can see the 5GHz signal. The only light showing on the router is the bright white light at the front.
Note that this router is a replacement for the previous (light stopped working) and with that most of my devices were connected to the 5GHz wifi. It's in the exact same place as previously, which is my desk. My desktop computer is connected by ethernet and that connection appears fine - when I've tested speeds they are pretty much what I'd expect.
on 28-05-2024 09:54 PM
Do your devices all support the 5GHz band? It does sound like poor wireless reception, with which, I can help a lot.
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
In other words, I try to help you optimise your Wi-Fi connection. If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
