full fibre broadband problem with phone lighting up every 30 minutes
kbleigh
Message 19 of 19
Every 30 mins, day and night, the landline phone display lights-up with the message "external call".
I think this may be a router problem - can it be resolved by a firmware fix or a change of router?
18 REPLIES 18
Message 1 of 19
That's great news kbleigh, thanks for letting us know
kbleigh
Message 2 of 19
Hi Debbie & KeithFrench,
Just thought I would let you know that I have resolved the issue with "slow loading" apps on Android phone.
It was nothing to do with the Router, but was caused by a weak 4G signal interfering with the WIFI.
It has been rectified by disabling "WIFI Calling" in the Network settings of the mobile phone.
All working fine now.
Thanks again for your help
KBLeigh
kbleigh
Message 3 of 19
HI KeithFrench,
The apps which load very slowly are the "separate" BBC Weather, Sport and News. However, the "combined" BBC app, from which you can invoke Weather sport etc works fine!
Other apps which "buffer" for about a minute before loading are M &S, Sainsburys, Hobbycraft, i.e. "retail" type apps.
Once the BBC apps have loaded the performance between "screens" is fine.
I'm not a "techie" and so I don't really want to start changing the Router settings at this stage.
Thanks for your help
Kbleigh
Message 4 of 19
Hi @kbleigh
What sort of apps are these? In the 5464, have you looked at the firewall settings, it needs to be on medium, not high.
If you connect a wired device to the ONT in place of the 5464, what speeds do you get using a speed test?
Message 5 of 19
Hi Debbie,
Tried 30+ minute switch off of Router as you suggested, but performance still v slow on the apps I mentioned earlier...
Kbleigh
kbleigh
Message 6 of 19
Hi KeithFrench,
Thanks for your interest in my problem.
My router is a TALKTALK router, the make is SAGEMCOM and the model no is FAST 5464-2-T4.
I am on TALKTALK Full Fibre which was installed earlier in the year (March2024).
General internet performance, such as other websites, whatsapp, google, downloads from "catch-up" etc is fine.
Its just certain Apps which run very slowly!
Kbleigh
Message 8 of 19
Hi @kbleigh
@Debbie-TalkTalk has asked me to help you with this. I assume that as part of the app loading it downloads stuff from the internet & it is network delays that cause them to load slowly, as they work on other WiFi networks.
However, I am going to need some more information about your broadband package.
2. What package are you on - full fibre?
3. What is ordinary internet performance like?
Message 9 of 19
Hi @kbleigh
It would be worth trying the 30 minute power down as this will start a new session.
kbleigh
Message 10 of 19
Hi Debbie,
I haven't tried a 30 min router power down since you applied the "fix" yesterday afternoon, but I did a few days ago.
I'll try it again if you think it will solve the problem.
Kbleigh
Message 11 of 19
Hi @kbleigh
I can't see any reason for why these apps aren't loading. Your router has the latest firmware version.
Have you tried a 30 minute power down of the router?
@KeithFrench have you come across this issue before?
kbleigh
Message 12 of 19
Hi Debbie,
I have re-installed them on my phone recently to ensure that they are the current versions but still get the problem...
As I said, they work perfectly on other WIFI networks and on 4G.
Kbleigh
Message 13 of 19
Hi @kbleigh
I'm so glad to hear this, thanks for letting us know 🙂
In regards to the apps, can I just check, do these apps have the latest software updates on the app store?
kbleigh
Message 14 of 19
Hi Debbie,
Thanks to you and Chris, the "fix" has rectified my problem with phone display flashing.
I do have another issue that you may have a "fix" for:
When I invoke certain Apps on my Android phone over my Talktalk full fibre WIFI, they take a very long time to load, buffering for 1-2 minutes.
This happens particularly with BBC Sport/Weather apps and some "retail" apps such as M&S and sainsburys.
When I use these apps on other WIFI set-ups (eg BT or Sky) they load instantly.
Can you help with this?
Kbleigh
Message 15 of 19
Hi @kbleigh
Have you experienced any further issues since my colleague Chris applied the fix yesterday afternoon?
Message 16 of 19
Hi kbleigh,
I've applied the fix, hopefully it should be OK now
kbleigh
Message 17 of 19
Hi Debbie,
I have added my name and account number to my Community Profile as requested, so that you can apply the fix.
Please let me know when the "fix" has been applied.
kbleigh
Message 18 of 19
HI @kbleigh
Apologies for this. I can apply the fix for this issue.
Please can you add your name and TalkTalk account number to your Community Profile.
