on 28-11-2024 03:06 PM
My router is not connecting to the internet the Orange light keeps flashing and ive opened a case nearly 24h ago
on 02-12-2024 08:57 AM
Hi Gabi1971,
Your connection appears to be up and running now, is everything OK at your end?
on 29-11-2024 09:42 PM
OK, thanks for trying all that. Wait for further advice from the support team, but be aware that they won't be back online until Monday.
on 29-11-2024 09:40 PM
Unfortunately not working
on 29-11-2024 04:52 PM
I am, aren't I? 🙂
It does help, because it indicates that your broadband connection is coming through fine. Try connecting a device directly by ethernet cable to the LAN port on the ONT. Then check that the ethernet cable connection between the ONT and router at both ends is sound and secure. Finally try switching off the router for a full 30 minutes. Let us know if that helps.
on 29-11-2024 04:28 PM
Yo smart guy
on 29-11-2024 04:26 PM
Not sure if that helps
on 29-11-2024 04:25 PM
The ONT - box on the wall where the fibre comes in - not the router.
on 29-11-2024 04:19 PM
Not very helpful. Its Orange keeps flashing
on 29-11-2024 06:41 AM
Thank you. I've run a test on the line now which hasn't detected a fault. What lights are currently on the ONT box on the wall please? Does the connection work if you remove the router and connect wired directly at the ONT please?
on 28-11-2024 04:28 PM
Yup
on 28-11-2024 03:24 PM
Hi Gabi1971,
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
