Wifi not working
Gabi1971
Message 12 of 12
My router is not connecting to the internet the Orange light keeps flashing and ive opened a case nearly 24h ago
Gabriela
11 REPLIES 11
Message 1 of 12
Hi Gabi1971,
Your connection appears to be up and running now, is everything OK at your end?
Message 2 of 12
OK, thanks for trying all that. Wait for further advice from the support team, but be aware that they won't be back online until Monday.
Message 3 of 12
Unfortunately not working
Gabriela
Message 4 of 12
I am, aren't I?  🙂
It does help, because it indicates that your broadband connection is coming through fine. Try connecting a device directly by ethernet cable to the LAN port on the ONT. Then check that the ethernet cable connection between the ONT and router at both ends is sound and secure. Finally try switching off the router for a full 30 minutes. Let us know if that helps.
Message 5 of 12
Yo smart guy
Gabriela
Message 6 of 12
Not sure if that helps
Gabriela
Message 7 of 12
The ONT - box on the wall where the fibre comes in - not the router.
Gabi1971
Message 8 of 12
Not very helpful. Its Orange keeps flashing
Gabriela
Message 9 of 12
Thank you. I've run a test on the line now which hasn't detected a fault. What lights are currently on the ONT box on the wall please? Does the connection work if you remove the router and connect wired directly at the ONT please?
Gabi1971
Message 10 of 12
Yup
Gabriela
Chris-TalkTalk
Message 11 of 12
Hi Gabi1971,
  • Name
  • Telephone number
  • Alternative contact number
