on 22-08-2023 06:48 PM
I got my Fibre 500 today, downloading speed seems very good as expected however, the upload speed is between 1.5 - 7 Mbps. which is well under SLA (71Mbps) even though the speed test on eero app shows 35Mbps upload.
Also, no eero advanced security is enabled.
Could you please help
Thank you
Pintu
on 24-08-2023 08:58 AM
No Problem 🙂
on 24-08-2023 08:47 AM
Sure! I will do that in the evening and let you know.
Thank you
Pintu
on 24-08-2023 08:38 AM
OK, can you power off the ONT and all equipment for 30 minutes to fully reset the session.
on 24-08-2023 08:33 AM
Hi Karl,
I used to get atleast 7Mbps upload across all of my devices, on fibre 65.
on 24-08-2023 08:24 AM
To verify the upload speed over wifi is being recorded correctly, can you open up the browser on your phone, type speedtest into the google search box and run the google speedtest.
does it show the same as the one you have been using ?
on 24-08-2023 08:18 AM
Hi Kar,
Yes! Tests were done just next to the eero and I have only one eero connected to the ONT.
I have connected my previous TalkTalk hub (Black router) to test. The result was the same as Eero.
I have tested at least 3 mobile devices (2 of them support wifi6) and 2 Windows laptops
Thank you
Pintu
on 24-08-2023 07:29 AM
If speed wired is ok, but still low over wifi , it could be wifi interferance or the device itself, or the router (Eero).
were the wifi tests done close to the eero ? Do you just have the one eero connected to the ONT ?
on 23-08-2023 08:43 PM
Hi Karl,
just done the speed test as you recommended.
Result - Sam Knows Speedtest
Download 521.1 Mbps
Upload 53.9 Mbps
Latency 3.4 ms
However, upload speed over wifi remain same.
How to fix it?
Thank you
Pintu
on 23-08-2023 07:56 AM
Can you try a wired speed test via Sam Knows Speedtest and let me know what the results show.
This will rule out a wifi issue.
on 22-08-2023 07:55 PM
a screenshot of speed test
