Home Phone
Caller ID
popboffy1
Message 22 of 22
Sorry Michelle , the quick fix you suggested lasted about 24hrs I've now lost it again, but thanks anyway , I've switched it off again from my add ons and will try again tomorrow, obviously a fault with the lines.
21 REPLIES 21
Message 1 of 22
Have our team made contact since our last post?
Message 2 of 22
OK thanks, I'll pass it over to our network team and ask them to take a look. I'll let you know when I receive an update or they may contact you directly
popboffy1
Message 3 of 22
Just "Incoming Call" with no name or voice notification .
Message 4 of 22
OK thanks. What does it show now when you get an incoming call?
popboffy1
Message 5 of 22
No, still not working this morning.
Message 6 of 22
Hi popboffy1,
Hope your wife is OK and feeling better. Just to confirm, is caller display still not working this morning?
popboffy1
Message 7 of 22
Been to hospital outpatients most of afternoon with wife , tried on my return, NOT WORKING.
Message 8 of 22
OK thanks. Please let us know if the issue reoccurs
popboffy1
Message 9 of 22
Hi Chris, it is working at the moment.
Message 10 of 22
Thanks. I've made a change, can you please retest and let me know if it's now working
popboffy1
Message 11 of 22
No Chris not working at the moment, tried three times yesterday over a six hour span, didn't work twice but did work on the middle try.
Message 12 of 22
popboffy1
Message 13 of 22
Hi Chris,
Unable to ascertain at present , wife poorly and still in bed, usually until 10ish, I'll give it a ring later and inform you one way or another.
Message 14 of 22
Hi popboffy1,
Just to confirm, is it still not working?
popboffy1
Message 15 of 22
Ooops it lasted 3hrs this time , it's off again , think we'll give it up as a lost cause.
popboffy1
Message 16 of 22
Yes.
popboffy1
Message 17 of 22
OK Caller Display back on didn't notice had to log out and then log back in to take effect, instruction wasn't very clear.
popboffy1
Message 18 of 22
No can do, I have ticked to put on when I confirm it disappears, probably have to wait until  my previous "Cancelled" instruction is rectified , I'll try again in a couple of hours.
Message 19 of 22
Could you switch it back on in My Account and let me know when you've done this. I'll then take a look to see if I can see anything stopping it working on our side
popboffy1
Message 20 of 22
No, as soon as I noticed it wasn't working, yet again, I followed Michelle's instruction to take it off and wait a couple of hours before turning it back on, which I did and it worked albeit for a short while,
