on 11-08-2023 04:50 PM
I’m hoping someone can help me.
Recently I have been having issues with my landline displaying ‘call’ every time someone rings, instead of their name.
It has worked in the past and I have checked the account and caller display is activated.
Hopefully, this issue can be solved.
Thanks in advance…
on 18-09-2023 09:36 AM
OK, thanks. Everything that I can see at our end is showing that it's enabled. Are you able to test with a different telephone or test your phone on someone else's line?
on 18-09-2023 08:24 AM
No, still not working.
milly.
on 18-09-2023 08:19 AM
OK thanks. I've made a change, could you please retest and let me know if it's now working
on 18-09-2023 08:14 AM
Ho Chris,
I have been checking it all weekend and it has not worked once.
it is so frustrating- is there anything else I or you could do?
milly
on 18-09-2023 07:02 AM
Hi milly,
Is it still not working?
on 15-09-2023 04:49 PM
Hi Chris,
have just retested and unfortunately the display is still not working properly.
I can try again later. Is there anything else you can do?
milly.
on 15-09-2023 02:44 PM
OK thanks, have a great weekend 🙂
Ok. Thanks for that. Will retest in an hour or so and let you know the outcome.
milly.
on 15-09-2023 02:18 PM
Hi milly_50,
I've re-added caller display, could you give it a couple of hours and the retest
on 15-09-2023 12:04 PM
Sorry, still can't at the moment. I'll try again later
on 15-09-2023 11:32 AM
Ok, thanks for the update.
hopefully you will be able to add it back to my account soon.
milly.
on 15-09-2023 10:01 AM
I can't re-enable it at the moment, I'll try again in an hour
on 15-09-2023 08:40 AM
OK thanks, I'll remove it now and re-add it in about an hour
on 15-09-2023 08:30 AM
Hi Chris,
I have just tested the phone and unfortunately it is still not working.
milly.
on 15-09-2023 08:16 AM
Sorry that this has happened again. Could you just confirm that it's still not working and if it isn't I'll remove and re-add it
on 14-09-2023 05:19 PM
thank you.
hopefully the caller display will be fixed soon.
on 14-09-2023 05:04 PM
I have re-escalated this to the support team for you.
on 14-09-2023 04:49 PM
Hi Chris,
I’m writing this message here because my caller display has stopped working again.
The fix last time was for you to remove then add it back to my account.
please could you do this again for me.
best wishes,
milly
on 18-08-2023 07:35 AM
so glad to hear this.
on 17-08-2023 05:27 PM
Hi Chris,
I can happily say that my caller display is now working!
Thank you so much for all your support and help to get it up and running again.
Milly.
