on 24-05-2024 05:11 PM
I have had to change my package which has now gone up so I only what broadband . Don’t use home landline very much
on 28-05-2024 10:07 AM
Hi MargaretDowns
I suspect you may be out of contract call the loyalty team on 03451720088 They will be able to see what options are available
on 24-05-2024 05:21 PM
Do you have an anytime phone boost or a call boost included in you package?
If so staff can remove this for you.
If not then you are not saving anything as the phone is part of the line into your home.
You can either not use the phone for outgoings calls so you won't incur any calls charges, or if you don't want the phone at all, disconnect it from the socket but you may miss incoming calls that others make to you.
Please confirm if it's a boost you need removing.
Thank you.
