on 31-10-2023 10:18 AM
When I pick up the phone the dial tone has a loud crackle, which interestingly seems to go when the call is connected.
After a call the crackle has gone from the dial tone, but comes back after a couple of minutes of non use.
I did run the online line check which came back as no fault, but the crackle is still there over the dial tone.
Broadband download speed is not affected at all, still getting the normal download speed of around 45 Mbps, but upload seems a bit slow at 3 Mbps
on 16-11-2023 08:23 AM
Hi Debbie,
OK, thank you very much.
I didn't see Openreach down the road yesterday.
Steve
on 16-11-2023 07:28 AM
Hi Steve
I will contact Openreach today for more information/updates on this fault.
on 14-11-2023 11:54 AM
HI Steve
Apologies for the confusion, no they are still working to fix the fault but as soon as they have completed the work I will let you know.
Thanks again.
on 14-11-2023 11:48 AM
Ah OK, I took it like they'd said they'd cleared the problem and were just monitoring it.
on 14-11-2023 09:15 AM
Hi Steve
Openreach are still working on the fault, once they have confirmed all the work has been completed then I will let you know.
on 14-11-2023 09:12 AM
Good morning,
The line still isn't exactly clear, although the load crackling has gone.
Upload speed is still 3 Mbps, it starts at 7 then rapidly drops to 3
As far as I can tell, nothing has changed from before yesterday.
on 14-11-2023 07:09 AM
Morning Steve
Openreach have advised that the next review date is 15-11-2023 (for updates on fault)
I will keep monitoring for updates.
on 13-11-2023 11:35 AM
Thanks for the update and please let us know how you get on.
13-11-2023 11:32 AM - edited 13-11-2023 11:38 AM
Morning Debbie,
Openreach have just turned up and he's somehow going to get new wiring through the conduit, six right angle bends and about 150 yards from us.
There are a few access points along the way though.
I also do not know if he is going to renew everyone's connection, or just lay enough wires for when there are more problems.
Our neighbour but one on the other side of the road gets bad connections when it's rained a lot as well, but there is no conduit on his side of the close.
So 10 out of 22 houses are unlucky.
on 13-11-2023 08:37 AM
Hi Steve
Thanks for the additional information.
I agree, this work should have been carried out previously by Openreach.
I will continue to check the fault ticket today for updates from Openreach.
11-11-2023 12:24 PM - edited 11-11-2023 12:24 PM
Openreach have been back again today and tried to find the fault.
Evidently my line has various leaks both to earth and to other lines.
There has been a conduit laid at some time, but only a few lines have been routed through it.
He said they should all have been replaced at the time rather than all the bandaids over the past years.
Coming back on Monday hopefully to sort out our close properly with new wires fed down the conduit.
Many of the houses down our close have been having problems, I think Openreach should have sorted this properly ages ago.
It also looks like the conduit doesn't go past my house, (I'm at the end), so maybe only half will be able to get the new wiring.
on 10-11-2023 08:56 AM
Hi Steve
I'm sorry that the engineer didn't keep you updated yesterday.
It looks like this fault will be part of a bigger fault. Once Openreach update the ticket again with an update then I will let you know.
on 10-11-2023 08:46 AM
Thank you for the update.
Shame he didn't let me know personally...
This whole estate has had the wiring just buried underground without any conduits, now that it appears that the wiring is coming to end of life it's going to be a major problem I suppose.
The Openreach engineer said that a house just up the road has a call in for similar problems.
on 10-11-2023 07:08 AM
Morning Steve
The fault is still open with Openreach as the engineer has left notes to advise that they need more time to work/resolve this fault.
on 09-11-2023 12:55 PM
Hi Steve
That's great. Hopefully we receive updates on the fault ticket this afternoon.
on 09-11-2023 12:52 PM
Just had a ring at the door, Openreach has now checked our master socket, and there is a fault.
The line from the master socket to the box in the pavement outside our drive is OK.
He is now checking from that box along our road to find out where the fault lies.
on 09-11-2023 09:25 AM
Hi Steve
Ok, I will let you know as soon as Openreach confirm that the fault has been resolved.
Thanks again.
on 09-11-2023 09:14 AM
Download is OK at about 47 Mbps, upload is down to 2 Mbps unfortunately
on 09-11-2023 07:51 AM
Hi Steve
The fault has been assigned back to the line engineer again this morning so they must still be working to fix this fault.
How's the connection been since last night?
on 08-11-2023 01:47 PM
Hi Steve
That's good news 🙂
I've checked and Openreach haven't closed the fault ticket but it's likely if the speed has increased then they have been working on the fault.
As soon as the engineer updates the ticket I will let you know.
