Home Phone
Digital voice
Lerch
Message 3 of 3
I have fibre 150 how do I get the digital voice adaptor the video says you need for a eero router.
Arne-TalkTalk
Message 1 of 3
Hi Lerch
You are currently on data only through Openreach so you will need to contact our full fibre Team who will be able to assist you.
Regards.
Message 2 of 3
Who has supplied your full fibre connection, Openreach, CityFibre or another company? Did you request Digital Voice when requesting the upgrade? If it is CityFibre then, unless things have changed, you cannot add it afterwards.
