Home Phone
Elderly Parent How to disconnect call automatically
MTW73
Message 2 of 2
Having a problem after my Mum receives/makes a call. It appears if she does not press the red button on her phone (to disconnect the call) the line stays open. Subsequently anyone then ringing her automatically goes straight to voicemail. Is there a solution to clear the line after a call without her having to remember to press the red button all the time please?
1 REPLY 1
Chris-TalkTalk
Message 1 of 2
Hi MTW73,
Have you tested with a different telephone to see if its a problem with the phone?
