Home Phone
Home landline not working correctly
igmit
Message 20 of 20
High amount of noise nearly drowning out dial tone.
Cannot dial out.
Phone rings once on incoming call then stops, when phone is picked up can only hear dial tone.
NTE 5C MK 4 main telephone socket, all testing done from the test outlet within NTE 5C MK 4.
19 REPLIES 19
Message 1 of 20
That's great igmit, thanks for letting me know 🙂
Message 2 of 20
Problem sorted by Openreach engineer, all well within the quoted timeframe. Can’t grumble at that service.
Many thanks.
Message 3 of 20
Message 4 of 20
Thanks Chris, Just had a text saying there going to investigate.
Regards igmit
Message 5 of 20
Openreach will investigate over the next 72 hours and may contact you directly if they need to access your home
Message 6 of 20
Many thanks Chris, Is there a timescale for this or do we wait for Openreach to get in touch?
Message 7 of 20
Line test is still failing but for a different reason so I'll log this out to Openreach for further investigation.
Message 8 of 20
Message 9 of 20
🙈Give me 2-minutes. I will re-connect then at 15:30
Message 10 of 20
Apologies, I was waiting for you to confirm that it's connected to the test socket. If it's still connected I'll do the test now
Message 11 of 20
Hope you did the test Chris, as I needed to re-assemble the NTE 5C MK 4 to get my internet back 😉
Message 12 of 20
Message 13 of 20
Will do, give me 2-minutes.
Message 14 of 20
OK thanks. Would you be able to connect the telephone to the test socket again and I'll run the test again
Message 15 of 20
Not at the moment. Internal wiring is back connected.
Message 16 of 20
Line test is picking up a potential problem. Is your telephone currently connected directly to the test socket?
Message 17 of 20
Thanks. I'll take a look at this now and get back to you.
igmit
Message 18 of 20
Community Profile updated.
Chris-TalkTalk
Message 19 of 20
Hi igmit,
  • Name
  • Telephone number
  • Alternative contact number
