Home Phone
Home phone
Tony70
Message 7 of 7
Hi my cordless dect phone says fixed line in use when trying to call it so get no inbound calls p.s only got the one handset connected to the line except for my broadband which works fine
anthony abram
6 REPLIES 6
Message 1 of 7
Hi Tony,
Thanks for the update and I'm glad to hear that your voice service is now working ok.
Michelle 🙂
Message 2 of 7
Hi tried new filter and handset was still saying fixed line in use then I reset the base station and can now receive incoming calls thanks
anthony abram
Tony70
Message 3 of 7
Hi Debbie tried with a new filter but was the same handset kept saying fixed line in use then I rest the base station and now can receive incoming calls thanks for your help
anthony abram
Message 4 of 7
Message 5 of 7
Hi thanks I'm o n fiber 65 will test socket tomorrow I and also try new filter and let you know more when tested
anthony abram
Message 6 of 7
What package are you on? Unless full fibre, what happens if you move the phone to the test socket behind the master socket's removable faceplate, and connect it via a new microfilter or at least a known good one?
