Home Phone
Just joined talktalk.
hosays299
Message 28 of 28
Hi we just joined u and have another issue.
When i or people call us the show withheld on the phone why is this??
Can someone explain why and what needs to be done.
27 REPLIES 27
Message 1 of 28
The relevant body for complaints is CISAS, @hosays299.
8 weeks / deadlock letter:
         EC4M 8BU
Message 2 of 28
Is it the obersman after 8 weeks??
Message 3 of 28
Hi @hosays299
Sorry, but as a customer myself I have no access to TalkTalk systems. Therefore I cannot comment on what you asked me.
Message 4 of 28
Just been told again it going then it not.
This time by complaint manager
What next ??
She has exhausted all here resources. !!
Message 5 of 28
I am glad someone understands me.
I trying chat again as the teach team couldn't transfer me back to complaint team.
Is anyone training correctly
Gliwmaeden2
Message 6 of 28
@sabelo-TT, @hosays299 is NOT talking about CALLSAFE.
Caller Display is an entirely different service and simply shows the number calling, just as it would when a call comes in on a mobile phone display.
My mum phoned me yesterday and the service works perfectly fine, showing her number still from yesterday's call. I'm on Fast Broadband, however.
@hosays299, several people have had trouble with it and their VOIP service. Sometimes a service is removed, then reapplied to see if that resolves the issue but it takes a few hours between changing settings to switch these services off and back on.
Any "changes pending" notices need to be cleared by a helpful support agent before any further changes can be made. That's always been an issue with My Account.
hosays299
Message 7 of 28
OK but ur teach team are saying it is Caller displayCaller display
Message 8 of 28
Not at all as it's our CallSafe feature that will no longer be available.
hosays299
Message 9 of 28
Hi the agent on ur teach team told me caller display has gone is this right??
Message 10 of 28
With Caller display, it's different. Meaning so, here are some reasons Caller Display might not work:
Withheld numbers - if the caller has withheld their number it won't appear in your display. Try calling from a number you know isn’t withheld to see if this remedies the problem.
Faulty display screens - try using a different phone with a display screen. If Caller Display works on this phone then it’s likely there’s a problem with the first one.
Interference - sometimes faulty equipment or devices can interfere with Caller Display.
Try the following:
  1. Disconnect all your devices leaving just your phone attached.
  2. Test to see if Caller Display works.
  3. Now reconnect each device one by one, testing Caller Display each time.
If reconnecting a device stops Caller Display from working, that's the one that’s causing the interference. Try not to use it while you use Caller Display.
hosays299
Message 11 of 28
I did not get the 14th one ??
Does this mean no longer do caller display??
Message 12 of 28
With regards to the CallSafe removal feature, there are 3 stages of communication:
1st Comms – Important Information about CallSafe was shared on the 14th July.
2nd Comms – Reminder: Important Information about CallSafe will be sent on the 28th July.
3rd Comms – Important: CallSafe has now been removed will be sent on the 28th August.
hosays299
Message 13 of 28
Hi when where new customer informed of this and is there a replacement coming
hosays299
Message 14 of 28
I 2as talking about caller display??
Message 15 of 28
@hosays299, that's correct as CallSafe will no longer be available to new users starting 9th July 2025. Additionally, the feature will be fully removed from all systems and customer accounts by 31st August 2025. This change is happening because the technology behind CallSafe is reaching its End of Life (EOL), meaning it’s being phased out and will no longer be supported.
hosays299
Message 16 of 28
Just been told via chat u have removed call display for All customers??
@sabelo-TT @KeithFrench @Gliwmaeden2 @amahle-TT  are they telling me the truth??
Message 17 of 28
As I do understand your concerns about this @hosays299, I would kindly ask for your patience with this as I assure you that the team will get this resolved for you.
hosays299
Message 18 of 28
Hi I used live chat a was chatting to customers service agents i believe the technical person put me through to them !!
Have a open complaint as then agent seems not to understand me reporting a home phone service issue with caller display.
Hopefully the complaint does it but why should I have to open a complaint to get u to fix a service issue.
Seems ur agents do not know what to do.
I in the end explain it 3 or 4 times. But still not sure they understand it.
Very bad service. Not what epexct from a big isp provider
sabelo-TT
Message 19 of 28
We hear your concerns about this @hosays299. If I may kindly ask, were you bale to get in touch with our Full Fibre team using the contact details you were provided?
Message 20 of 28
Sadly the agent shraddha did not get what i was saying sent me a email on caller display on how to use it. Then asking if i could try another phone but i did not have another phone and the other issue is on my account it shows pending call features why is it showing pending call feautres
@amahle-TT can i ask why the chat live seems not to want to help spent over 30 mins and still no where fast
they seem to give me info i can get from ur website
Why was caller display working then not only been with y a sort time.
They have also asked to disable caller display why as that when i need it working. also asked to try from a number that is not withheld my mobile is not and is the same shows withheld
How is this help full to my issue
If your mobile number is not withheld but you’re still experiencing issues with calls, you may want to check your network settings or ensure that your phone is properly configured for receiving calls. Additionally, ensure that your mobile phone is updated to the latest software version for optimal performance. If the problem persists, exploring options like checking for any network outages might be helpful.
Can someone from talktalk explian why u not allowed to simple report a issue ceo office here i come for something ur agents can not do
