Home Phone
Landline divert to mobile
Jansnooka
Message 12 of 12
Hi how do I set up call divert to my mobile as I don't have a landline phone just now do I need to have a landline phone to set it up thanks
Jan Rathbone
11 REPLIES 11
Message 1 of 12
Message 2 of 12
It would usually only be done when a fault was on the line and you had no other option for keeping in touch.
Find a friendly neighbour who can let you use the phone plugged in to your BT socket for the few minutes it takes to set this up.
Jansnooka
Message 3 of 12
Hi I was told it could be done from your end thanks
Jan Rathbone
Message 4 of 12
It has to be done from your side via the landline handset, is it possible to connect or even borrow a handset to connect the master socket and follow the instruction given
Jansnooka
Message 5 of 12
Hi I can't set up call divert from my landline as I don't want my ex partner to no about call divert it was meant to be done on Saturday  I spoke to casey o. Chat  can you sort this please
Jan Rathbone
Message 6 of 12
Jansnooka
Message 7 of 12
Account number is *** removed for security ***
Jan Rathbone
Message 8 of 12
@Jansnooka Can you add your account number to your community profile and I can look into this.
Thank you.
Jansnooka
Message 9 of 12
Hi my landlines was meant to be diverted to my mobile yesterday and it hasn't been sorted
Jan Rathbone
Arne-TalkTalk
Message 10 of 12
Hi Jansnooka
Did you manage to sort this out?
let me know if you need any assistance.
Regards.
Gliwmaeden2
Message 11 of 12
You set it up as a boost via My Account, @Jansnooka, and there is a monthly charge.
But to activate it, you need to press numbers from the landline phone etc.
It can be set up by Talktalk when there's a fault, so in theory it should be possible to ask them to do this for you, but you won't have direct access to controlling it without a landline handset yourself.
For example, even if you never want it switched off, you might have a change of mobile number that you needed to then set it up for. Might be simpler to buy a basic handset!
https://community.talktalk.co.uk/t5/Articles/About-Call-Divert/ta-p/2205322
Staff are not on here at weekends  - they respond during the day Monday to Friday.
