Home Phone
Landline fault taking a long time to resolve
vpalm28
Message 6 of 6
My landline fault is taking a long time to fix as it's the second time I've got in touch to get
someone on the case and get in touch with an engineer to tell me what's going on.
5 REPLIES 5
Message 1 of 6
Yes, hopefully it will be 🙂
Message 2 of 6
Thanks for the update Chris. They're doing a lot of work in my area updating the wiring so maybe after that's done
all will be well.  Thanks again.
Chris-TalkTalk
Message 3 of 6
Hi vpalm28,
The fault is still in hand with Openreach, they've linked it to an infrastructure event so this will probably be affecting a number of customers. If you don't hear anything later today can you bump the thread tomorrow and we'll check again
Message 4 of 6
Thanks for the info Keith.
Message 5 of 6
