Home Phone
Missed calls on landline
rob1950
Message 8 of 8
Hi, I'm getting MIssed Calls with No Number every 30 minutes on my landline, since a power cut last week. I'm using WiFi Hub 2 with the phone plugged into the router. Help would be appreciated!
7 REPLIES 7
Message 1 of 8
Hi @rob1950
I'm so glad to hear this, thanks for letting me know 🙂
Message 2 of 8
Hi Debbie
Your fix seems to have worked, I've had no more missed calls since this morning.
Thanks for your fast response. Great service.
Rob
Message 3 of 8
Hi @rob1950
Have you received anymore of these calls (every 30 minutes) since my last post?
Message 4 of 8
Hi @rob1950
Apologies, I've made the change again.
Please can you monitor the line and I will check in again with you later this afternoon.
Message 5 of 8
Hi Michelle
No, I'm afraid nothing's changed. I'm still getting Missed Calls every 30 minutes, at the same times as before the update.
Anything else you can try?
Rob
Message 6 of 8
Morning rob,
Is everything now working ok for you?
Message 7 of 8
I've applied a small update to your router, this should stop the calls.
Test and let me know if they stop.
