on 27-01-2026 12:25 PM
I have no dial tone, just background static on my landline. I can’t make or receive calls. If I do call my phone from my mobile I get message saying I’m on the phone and then sent to voicemail.
I’ve tried the phone in the main socket and same thing happens!! It’s sort of like when someone calls you and doesn’t end the call at their end!!
I’ve run a line test and this has come back saying everything is ok??? My Wi-Fi router is working perfectly though, which uses same wiring in the house and the same main socket I used for testing. It feels like there’s some sort of issue at the exchange.
on 09-02-2026 04:00 PM
I am at home now
on 09-02-2026 08:29 AM
Hi there @Vonney1, thank you very much for being patient with us while we having this looked into. Kindly confirm if you are currently at home so we can run diagnostic on the issue.
on 09-02-2026 07:05 AM
@Gliwmaeden2 thank you for the support.
on 07-02-2026 11:04 PM
See my last post to you, @Vonney1 [#55]. No staff support at weekends.
07-02-2026 11:56 AM - edited 07-02-2026 12:05 PM
Hello, @siphosethu-TT and @Mandisa-TT or @Thabile-TT or whoever is dealing with my fault now,
Can you give me an update on what is being done to fix my landline issue please?
on 06-02-2026 10:55 AM
No problem, I'll keep in touch and keep you posted on the matter. Thanks
on 06-02-2026 10:44 AM
Thank you @siphosethu-TT I just hope this gets resolved soon. I first posted about this issue on 27 January and so far have just been repeating the same checks over and over again. Something needs sorting soon.
I’m going to have to go offline now, will check in again later.
on 06-02-2026 10:38 AM
Thank you for confirming that for me, we currently having this looked into for you. As soon as we have an update I'll get back to you. Thanks
on 06-02-2026 10:34 AM
I’ve just looked at the page from that link and can confirm I’ve already read it and done all that it recommends.
on 06-02-2026 10:29 AM
Not sure if that involves a check from your end or mine??!!
I’ll tell you what I’ve done.
1 I’ve run checks through your website which bizarrely is saying there’s no problem
2 I’ve plugged in wireless and a wired phone to all sockets including master socket and still not working
3 I’ve removed the cover from the master socket and plugged wired phone into test socket - still not working & no dial tone. Master socket is NTC5C Mk4
The phone is still not working. If I call the phone message says I am on a call and goes to voicemail. But internet is working fine.
I can’t think of any other tests I can run.
on 06-02-2026 10:21 AM
on 06-02-2026 10:18 AM
Will need to run diagnostics to confirm them.
06-02-2026 10:14 AM - edited 06-02-2026 10:18 AM
If you tell me now what checks I need to do because I may have already done them. If so, I can answer your questions now.
on 06-02-2026 10:11 AM
No problem, just let me know as soon as you get back as I'll need you to do a couple of things for me on your end.
on 06-02-2026 10:09 AM
Hi @Mandisa-TT
How are the checks going? I’m going to have to go out shortly, but will be back at home later this afternoon
on 06-02-2026 09:44 AM
on 06-02-2026 09:43 AM
Excellent @Mandisa-TT 👍
06-02-2026 09:41 AM - edited 06-02-2026 09:42 AM
Thank you for confirming. I will start the checks.
on 06-02-2026 09:40 AM
Yes @Mandisa-TT still not working
on 06-02-2026 09:38 AM
Great! Just to confirm you are still having issue with unable to make or receive calls on your landline?
