Home Phone
No Incoming or Outgoing Calls on Landline
Vonney1
Chat Champion
Message 156 of 156
I have no dial tone, just background static on my landline. I can’t make or receive calls. If I do call my phone from my mobile I get message saying I’m on the phone and then sent to voicemail.
I’ve tried the phone in the main socket and same thing happens!! It’s sort of like when someone calls you and doesn’t end the call at their end!!
I’ve run a line test and this has come back saying everything is ok???  My Wi-Fi router is working perfectly though, which uses same wiring in the house and the same main socket I used for testing. It feels like there’s some sort of issue at the exchange.
155 REPLIES 155
Message 61 of 156
The line test result has identified an issue that may be caused by equipment and wiring in your home.
These issues are most often caused by problems with internal wiring. Common causes are:
  • incorrect filter setup
  • old, worn or damaged wiring
  • use of an extension cable between the master socket and the router
  • connecting to a telephone socket other than the master socket - which is the socket where the telephone line enters your property
I'll need to perform the test again with your equipment disconnected to check the most likely cause.
I'll guide you through the steps needed. Once I've retested with the equipment disconnected I'll be able to tell you if an engineer is required or whether there are issues I can investigate with you through further checks
Message 62 of 156
Yes I have. And I’ve also removed the cover from the master socket and plugged a wired phone directly into the test socket
Message 63 of 156
Have you correctly connected the telephone cable to the telephone wall socket?
You will hear a click when inserting the telephone cable into the socket.
Message 64 of 156
It’s not VOIP we don’t have full fibre in this area, I have a traditional analogue landline. So the phone doesn’t search for a signal
Message 65 of 156
Can you take a look at the phones display, is it showing 'searching' or 'no signal'?
Message 66 of 156
The battery level is fine. I’ve also plugged in a wired phone directly and still no dial tone
Message 67 of 156
Can you check the battery level on your handset? It will look something like this.
Message 68 of 156
Yes it is
Message 69 of 156
Please can you confirm that the base station is powered on?
Message 70 of 156
I have a wireless one connected right at the moment, but I have also just tried a wired one - still no luck
Message 71 of 156
Which type of telephone do you currently have connected?
Is it wired or wireless?
Message 72 of 156
No problem at all with the internet
Message 73 of 156
Thank you very much for bringing that to my attention, don't worry about it I just need to confirm if it's still the case with your internet before we continue. Thanks
Message 74 of 156
I’m not sure whether you are aware, but I have already run connection tests and plugged a wired phone directly into the test socket.
Message 75 of 156
Thank you, from what we discussed last time I can confirm that you are not having any issues with the internet, correct?
Message 76 of 156
No I don’t
Message 77 of 156
No problem, do you have any active monitoring for life threatening health reasons which is solely dependent upon your TalkTalk Broadband or Telephone line?
For example, a care alarm, lifeline, health pendant or fall detector.
Message 78 of 156
If you need me at home to run tests then you’ll need to do them now because I will be out again tomorrow.
Message 79 of 156
Hi @siphosethu-TT
I am at home now
Message 80 of 156
Hi there @Vonney1, thank you very much for being patient with us while we having this looked into. Kindly confirm if you are currently at home so we can run diagnostic on the issue.
