on 27-01-2026 12:25 PM
I have no dial tone, just background static on my landline. I can’t make or receive calls. If I do call my phone from my mobile I get message saying I’m on the phone and then sent to voicemail.
I’ve tried the phone in the main socket and same thing happens!! It’s sort of like when someone calls you and doesn’t end the call at their end!!
I’ve run a line test and this has come back saying everything is ok??? My Wi-Fi router is working perfectly though, which uses same wiring in the house and the same main socket I used for testing. It feels like there’s some sort of issue at the exchange.
6 hours ago
Hi there @Vonney1, I'm just checking if everything was sorted when the engineer came, just to be certain the issue has been resolved.
on 10-02-2026 12:58 PM
Thank you so much:)
on 10-02-2026 12:43 PM
You too
Goodbye
on 10-02-2026 12:42 PM
Awesome and you are very much welcome.
Thank you for chatting in with us, enjoy the rest of your day and take care @Vonney1 🙂
on 10-02-2026 12:41 PM
Thank you.
Oh, after all this I’ll definitely be at home on the 16th!!!
Yes they should send you confirmation:)
on 10-02-2026 12:39 PM
No, nothing else at all. Thank you.
Can you just confirm whether I’ll receive a text from BT about the appointment
You are most welcome:)
Yes they should send you confirmation. However I would advise please make sure you are at home on the 16 to avoid missing the appointment.
on 10-02-2026 12:35 PM
That’s great, thank you.
Will I get a text from BT confirming this?
While I still have you online, I would like to confirm is there anything else that I can assist you with today?
10-02-2026 12:34 PM - edited 10-02-2026 12:34 PM
Thank you so much for your patience, I have successfully reserved the slot for you.
Reservation of a Openreach engineer appointment has been successful. Reserved appointment slot : February 16 2026,AM
on 10-02-2026 12:32 PM
Yes, 16/2/26 between 08.00 and 13.00 will be perfect
on 10-02-2026 12:30 PM
Am please between 08:00 - 13:00 will that be okay with you?
on 10-02-2026 12:29 PM
AM please
on 10-02-2026 12:26 PM
Sure. AM or PM slot?
AM please
on 10-02-2026 12:25 PM
That’s fine. Can you book the engineer for Monday 16/2/26 please?
on 10-02-2026 12:24 PM
Just to confirm would you like to book the AM or PM slot for Monday?
on 10-02-2026 12:23 PM
There is availability for Monday, however please note if you are eligible for Compensation, it will only be up until the earliest available date that I provided you with.
on 10-02-2026 12:20 PM
I’m sorry I can’t do that date either. Is there availability on Monday 16/2?
