Home Phone
No dialtone. Talk talk say it's fine !? What now?
rilian
Message 14 of 14
My line is dead, broadband and phone cut out suddenly. A wired phone into the test socket has no dialtone. The automated talk talk line test say there's no fault?
I work from home. Mobile coverage at home is marginal. What can I do to get this looked into?
Thanks for suggestions!
13 REPLIES 13
Message 1 of 14
Good afternoon,
How are you getting on?
Message 2 of 14
Hi rilian
Ah no problem 🙂
I will check in again with you after the engineer visit.
Message 3 of 14
That's fantastic, thank you very much
Message 4 of 14
Hi rilian
I've booked the first available appointment - 03/04 AM (8am - 1pm)
Will this date and time be ok?
Message 5 of 14
All day as needed (and any other day - this is critical) but I'd like a bit of warning if possible, and yes I've read your charges page and confirm I'm ok with that. Thanks very much!
Message 6 of 14
Hi rilian
No problem, I can arrange this for you.
Please can you provide your availability AM and PM?
Can you also confirm potential engineer charges
Engineer charges
rilian
Message 7 of 14
Yes please an engineer visit looks like what's needed, thanks very much
Message 8 of 14
Hi @rilian
The same fault has been detected.
The next step will be an Openreach engineer visit to the property. Would you like me to arrange this for you on the Community?
Message 9 of 14
Hi @rilian
Thank you. Just running the test now and I will post back shortly.
Message 10 of 14
Thanks - everything removed. It's a very short straight cable run from outside to the master socket (60cm) and the master socket is open and the faceplate removed.
I have a filtered faceplate and a few days ago I thought it had failed. While waiting for a replacement I removed the faceplate and plugged a micro filter into the internal socket which worked great for a couple of days but that failed yesterday. The line has been getting more and more unreliable over the last week or two with a disconnect for a few moments most days... and now it's failed completely.
Message 11 of 14
Hi rilian
The line test is detecting a loop fault and this can often be caused by internal wiring or equipment connected to the line.
Would it be possible to remove everything from the line (phone, router and faceplate) so I can run one more line test in this set up?
Message 12 of 14
@rilian
If you would like the support team here to look into this for you make sure that your personal details including TalkTalk phone number and/or account number are complete on your community profile (click here) so that they can link your forum identity with your account and then wait for them to respond.
Gliwmaeden2
Message 13 of 14
Staff will reply during the day, @rilian.
Check back then.
