Home Phone
No incoming calls, outgoing okay
kempas
Message 22 of 22
Just today people ringing our land line are getting disconnected and hearing a beep. Tried it myself from my mobile.
Ringing out though is fine, rang my mobile from the landline without issue.
Have run the service test but it says there is no issue when obviously there is.
21 REPLIES 21
Message 1 of 22
No Problem 🙂
If you do need help, you know where we are.
kempas
Message 2 of 22
Morning. Still ringing through okay when we test it but we don't get many calls on the land line anyway so will have to give it a few days or until someone tells us otherwise.
Will leave the corded phone disconnected in the meantime.
Many thanks, hopefully won't have to get back in touch 🤞😉
Message 3 of 22
How are you getting on?
Message 4 of 22
No problem and you too 🙂 We'll speak to you again in the morning 🙂
kempas
Message 5 of 22
Okay, many thanks Michelle.
Just rang house number from mobile and ringing through to cordless set okay so will leave corded phone disconnected and see how it goes.
Many thanks again, have a good day 😊
Message 6 of 22
Ok we'll check back in with you in the morning to see if this fault is still happening.
kempas
Message 7 of 22
Okay, front plate reconnected so cat5 and single extension connected but have left corded phone disconnected.
kempas
Message 8 of 22
Not a corded phone and can't really move our cordless base but can leave corded phone disconnected for now.
Only the one extension to the cordless base and cat5 extension to router will be connected.
Message 9 of 22
Thank you. You can now re-connect the phone again. Line test now shows - Line Test OK (In and Out). Do you have a different handset that you could test with please just to rule this out?
kempas
Message 10 of 22
Phone now disconnected,
Message 11 of 22
Ok, would it be possible to remove the phone for 15 minutes so we can run the test with no equipment connected to the line?
kempas
Message 12 of 22
Just the phone.
Message 13 of 22
Thank you. It's still showing the loop fault. Is it just the phone currently connected or the router too?
kempas
Message 14 of 22
On test socket only at the moment.
Message 15 of 22
Ok thank you. Could you post back here please once the phone is connected back at the test socket and we can run the line tests again to see how it looks in this set up.
kempas
Message 16 of 22
Í'll let you know when only test socket connected.
kempas
Message 17 of 22
Not at the moment but I can do so...
Message 18 of 22
Thanks for the update. Is the phone still connected to the test socket at the moment and I can run another line test?
kempas
Message 19 of 22
Thanks. It seems intermittent, testing from a mobile again and get the beep and disconnection.
Tried main phone connected to test socket only and first call got the same beep and disconnection but then second/third tries come through.
Reconnected box and tried again and now connects but was getting that yesterday.
To note. There was an engineer out to our shared down pole a few days ago, looked like he was replacing the down cable to a house two doors up so always potential they may have disturbed pole connections.
Message 20 of 22
I'm sorry to hear this. I've run a test on the line now which has detected a loop fault which can sometimes be caused by internal wiring or equipment connected to the line. Does your main socket have a test socket please?
