Home Phone
No number calls
Man1939
Message 6 of 6
I’ve been receiving calls every half hour, but the number appears as NO NUMBER. please can someone look into this. I have the Wi-Fi hub 2 router. After reading about this I be,I event is to do with the VOIP settings
Manhar
5 REPLIES 5
Message 1 of 6
Hi @Man1939
Did you receive anymore of these calls yesterday?
Message 2 of 6
Hi @Man1939
Apologies, I've applied the correct fix now.
Please can you monitor the line today and I will check in again with you tomorrow.
Message 3 of 6
I’m still having issues with the ‘no number’ problem, whatever fix that was applied appears not to have worked, also I don’t know if this is related but sometimes the incoming call ringtone does not ring on my extension phone although it works fine on the main unit connected to the router. Please can you look into this as urgently as possible
Many thanks
Manhar
Message 4 of 6
Good morning,
Just checking back in to confirm that the voice issue has been fully resolved and everything is now working ok for you?
Message 5 of 6
I've applied an update to the router, this should resolve the issue for you.
