Home Phone
One-way only calls on full fibre
JuneN
Message 28 of 28
Ever since switching to full fibre (in the hope that it might resolve the regular line distortion during calls) I now find that 50% of the time, when someone calls me, they can hear me clearly but all I hear is silence.  If I call them straight back it's usually fine.
Also, frequently when I make a call it just drops before connecting.
I've power cycled the Hub 2 router and reset it.  Have given up trying to speak to the Talktalk call centre.  After spending ages going through security and then waiting around, they decide that I need to speak to the Full Fibre team.  I get passed over to them, same delays then they decide that as it's a "phone issue" I need to speak to the main support team, and round we go.
Any ideas how to progress this?
June
27 REPLIES 27
Message 1 of 28
Morning June,
I'm really glad to hear this 🙂
Message 2 of 28
Morning @Michelle-TalkTalk - so far, so good; no dropped calls since moving over to the eero.
Thanks again for your help.
June.
Message 3 of 28
Morning @JuneN
Just checking back in to see how the voice service has been since your last post?
Message 4 of 28
That's great Geoff, thanks for letting me know
Message 5 of 28
Hi Chris
All sees to be working fine, thank you.
We'll give it a while to see if that has resolved the phone call issue.
Kind regards
Geoff
Message 6 of 28
OK, I've changed the profile, it should take effect in the next few minutes
Message 7 of 28
Message 8 of 28
Hi Chris/Michelle - ok, cables have been swapped so now:
Fibre wallbox ==> eero port 1
eero port 2 ==> grandstream DVA ==> telephone handset
Please go ahead with the config change to enable the eero.
Kind regards
Geoff.
Message 9 of 28
Message 10 of 28
Hi Chris - no, I'm liaising with you on Mum's (June) behalf so I'm miles away on a separate connection.
Thanks - Geoff.
Message 11 of 28
Hi Geoff,
Could I just ask, are you posting from a device connected to your TalkTalk landline?
Message 12 of 28
Hi Chris/Michelle
Could you please make the config change for the eero to work tomorrow (Thurs 18th) please?  Ideally around 12.30 as I'll have someone available to swap the cabling around and connect the eero in place of the hub.
Please update the ticket when done.
Thanks - Geoff.
Message 13 of 28
OK Geoff, no problem 🙂
Message 14 of 28
Thanks, Chris.  Will probably be early Thursday afternoon, will update here when we're ready for the change.
Geoff.
Message 15 of 28
We can generally do the change between 7am-3:30pm. When you let us know we can usually do it straight away within those hours
Message 16 of 28
Hi Michelle - Geoff here (June's son).
Yes, the voice adapter arrived too, thanks.  Before you change the config I'll need to get someone to set up the TV and phone/iPad to use the eero's wifi so that everything will work once we switch over to it.
How much notice do you need to make the configuration change, and during what hours can it be done please?
Regards - Geoff
Message 17 of 28
Morning June,
Did the Digital Voice Adapter also arrive? We'll need to make a change to your profile for the eero to work. When would be the best time to do this as your connection will be down for up to 1 hour?
Message 18 of 28
Hi Michelle.
Thanks for sending the Eero.  Didn't get us very far, I'm afraid.  Got my son to swap over the routers, but when going through Eero setup on the app the Eero wouldn't connect to the Internet.  Tried resetting everything including the fibre modem, no joy.
Apparently when the engineers installed the fibre line they said an Eero would have to be plugged into the Hub2 to work, which doesn't make sense - but we tried it and it actually does work.   However, apart from being messy it still leaves the Hub2 in the equation.
Also, even in this configuration the ATA doesn't work when plugged into the Eero, only when plugged into the Hub2.
June
Message 19 of 28
Great, thank you 🙂 We'll check back in with you next week 🙂
JuneN
Message 20 of 28
Thanks, Michelle - will get it set up and try it for a couple of weeks to see what happens.  Will let you know.
June.
