on 02-07-2024 08:34 PM
Ever since switching to full fibre (in the hope that it might resolve the regular line distortion during calls) I now find that 50% of the time, when someone calls me, they can hear me clearly but all I hear is silence. If I call them straight back it's usually fine.
Also, frequently when I make a call it just drops before connecting.
I've power cycled the Hub 2 router and reset it. Have given up trying to speak to the Talktalk call centre. After spending ages going through security and then waiting around, they decide that I need to speak to the Full Fibre team. I get passed over to them, same delays then they decide that as it's a "phone issue" I need to speak to the main support team, and round we go.
Any ideas how to progress this?
June
on 30-09-2024 09:53 AM
Hi Geoff,
I'm glad to hear this and thanks for confirming 🙂
on 30-09-2024 09:42 AM
Morning Michelle. Restarted it again and looks like it is working again now, thank you.
Geoff
on 30-09-2024 06:06 AM
Good morning,
I'm sorry for the delay. This should now be resolved. Have you rebooted your eero and digital voice adapter?
on 29-09-2024 01:33 PM
I don't know, I am just a customer like yourself. The support team will be back online tomorrow to advise further.
on 29-09-2024 11:37 AM
Hi - is this resolved yet? Still having the same issue and nothing showing on the service status page.
on 28-09-2024 05:45 PM
This is a known issue.
https://community.talktalk.co.uk/t5/Home-Phone/Calls-over-VOIP/m-p/3067533#M161296
on 28-09-2024 03:23 PM
/Hi Michelle
Unfortunately voice is playing up again; incoming, the caller just hears the ring tone, when answered there's just silence. Outgoing calls she gets the engaged tone.
We've power cycled the Grandstream and remote restarted/firmware updated the eero, internet appears fine.
Don't seem to be able to run a connection test as it says we've still got the copper line as well as fibre.
Any ideas? Thanks - Geoff
on 23-07-2024 08:56 AM
Morning June,
I'm really glad to hear this 🙂
on 23-07-2024 08:53 AM
Morning @Michelle-TalkTalk - so far, so good; no dropped calls since moving over to the eero.
Thanks again for your help.
June.
on 23-07-2024 08:38 AM
Morning @JuneN
Just checking back in to see how the voice service has been since your last post?
on 18-07-2024 01:03 PM
That's great Geoff, thanks for letting me know
Hi Chris
All sees to be working fine, thank you.
We'll give it a while to see if that has resolved the phone call issue.
Kind regards
Geoff
on 18-07-2024 12:50 PM
OK, I've changed the profile, it should take effect in the next few minutes
on 18-07-2024 12:45 PM
OK, will do
on 18-07-2024 12:44 PM
Hi Chris/Michelle - ok, cables have been swapped so now:
Fibre wallbox ==> eero port 1
eero port 2 ==> grandstream DVA ==> telephone handset
Please go ahead with the config change to enable the eero.
Kind regards
Geoff.
on 18-07-2024 08:41 AM
OK thanks 🙂
on 18-07-2024 08:21 AM
Hi Chris - no, I'm liaising with you on Mum's (June) behalf so I'm miles away on a separate connection.
Thanks - Geoff.
on 18-07-2024 08:15 AM
Hi Geoff,
Could I just ask, are you posting from a device connected to your TalkTalk landline?
on 17-07-2024 07:43 PM
Hi Chris/Michelle
Could you please make the config change for the eero to work tomorrow (Thurs 18th) please? Ideally around 12.30 as I'll have someone available to swap the cabling around and connect the eero in place of the hub.
Please update the ticket when done.
Thanks - Geoff.
on 09-07-2024 11:02 AM
OK Geoff, no problem 🙂
