06-09-2024 01:48 PM - edited 09-09-2024 06:10 AM
I upgraded from Fibre 65 to Full Fibre 65 on 05 September 2024.
Since the upgrade I find that my 'Withhold Number' setting in My Account has switched itself over to the number being withheld. I have today twice unticked this option, but the tick just keeps returning. I DO want people I call to be able to see my number.
Also, my preferred 'Mobile Bar' option has always been set to bar calls to Mobiles. Since my upgrade, the check box has a tick in it, but I find I am still able to call Mobile numbers.
Would be grateful for help in sorting these issues.
Friday
Ok will add it to the list, Callsafe is actually showing as active on the account, I think this is another of the services that hasn't carried over to VOIP.
Friday - last edited Friday
Ok @Arne-TalkTalk . Can you include CallSafe in the log as well please. Following my upgrade to Full Fibre VOIP, without any warning or notification, my CallSafe has been switched off also, thus deleting my lengthy list of Callsafe approved and blocked numbers built up since CallSafe was introduced. I am unable to reactivate CallSafe, neither in My Account or via 1472.
Hope a speedy resolution can be found to these issues.
Friday
We are going to have to log this as a fault, the removal request from yesterday has not completed, usually it takes a few hours, in this case its still showing as pending.
Thursday - last edited Thursday
I received a 'We've made the changes you asked for' email which states that 'We've removed Caller Display'. In 'My Account' Telephone Settings list, Caller Display is still ticked. When I call the phone from my Mobile, it still shows as Withheld. So unsuccessful I'm afraid.
Thursday
Ok, will repeat the process from yesterday.
Yes I'm sure.
Are you sure those inbound callers are not withholding their numbers?
Wednesday - last edited Thursday
One step forward, and one back I'm afraid.... Now all of a sudden Caller Display isn't working. Inbound calls now show as 'Withheld'.
The Telephone Settings list does show Caller Display with a tick against it, but I'm afraid it's not working, whereas it was until this afternoon's changes. Please can you re-add Caller Display, thanks a lot.
Wednesday
Ok , ill remove it ASAP
Wednesday
Apologies for any confusion but I actually now would prefer the Mobile Bar to be deactivated so that calls to Mobiles are possible. Thanks a lot.
Wednesday
Ive re-added the mobile bar can you test it. If you need any boosts, that are not showing in My Account you can always post on here and we can add it while the missing boost issue is issue is still ongoing.
Wednesday
Thanks @Arne-TalkTalk
I can confirm that 'Withheld Number' is now showing unticked. The 'Mobile Bar' is still not showing on the list but it has deactivated, which is fine.
The only 'Call Boost' option that's showing is Evening and Weekend, but I guess I can call in if I want the Unlimited option.
Wednesday - last edited Wednesday
HI @aa2000
There is an know issue with My Account features now showing, its been raised previously sorry.
I will remove the withheld number, We will need to remove and re-add the mobile bar to reactivate it, there is a chance with the switch to VoIP its not carried over.
Any auto email can be ignored.
Tuesday
I re-escalated it on the 8th, but as you posted after that, it may have pushed it back.
The new thread will be removed.
Please only follow up on this one, @aa2000.
Wait for staff to reach it again, rather than posting, or the same thing will happen!
Tuesday - last edited Tuesday
Is there any update on these issues please, my thread was missed yesterday and today?
Many thanks.
on 08-09-2024 09:09 AM - last edited Tuesday
Hi OCE's
Following my upgrade to Full Fibre 65 VOIP on 5th of September, I am still experiencing issues with my 'Telephone Settings' in 'My Account'. The list of choices has shrunk from what it was prior to my FF upgrade and I find I am unable to make any changes. When I try to change options, I immediately receive an email confirming the change(s) have been made, but when I check back after 2 hours, the options remain unchanged and the changes are NOT actually made. Have tried a few times on both my 'Brave' and my 'Edge' browsers with the same results.
Currently my phone number is Withheld, but I actually DO want people I call to see my number. Also my calls to Mobiles are barred and the 'Mobile Bar' option is one of the number of options that have now disappeared from the list.
So, I would be grateful if the following could be restored:
Thanks a lot.
on 06-09-2024 02:08 PM
Thanks for the update. Once an option is selected then it can take up to 2hrs to take effect. We'll check back in with you on Monday to see how you're getting on.
06-09-2024 02:01 PM - edited 06-09-2024 02:02 PM
I usually use Brave browser without problem. I have just logged into my Account using Edge and have unticked the 'Withhold Number' checkbox. I got a message that no other change requests would be permitted for 2 hours. I just tried to make an outgoing call though and my number was shown as 'Private Number' and I WAS able to dial my Mobile despite the tick in the Mobile Bar checkbox.
on 06-09-2024 01:53 PM
Good afternoon,
I'm sorry to hear this. Have you tried using a different browser?
