Home Phone
VoIP dropping out - regularly 😢
Willow27
Message 13 of 13
I have had many calls just drop off on a fairly regularly basis. Most embarrassing and very very inconvenient. - like yesterday when was on the phone to my doctor!
I have tried other handsets too.
I have the eero 6 hub.
what can I do?
12 REPLIES 12
Message 1 of 13
Hi Paul,
I'm really glad to hear this. If this does happen again then please let us know.
Willow27
Message 2 of 13
Well, after a fortnight and with a few calls in that time, I can say the problem I had with the line dropping out was much better. I did have one drop out, which is a shame - and a bit confusing to me.
 Can anyone explain why a reboot of the DVA would/could sort the issue?
Anyway - bottom line is that it seems much better so thank you for your help. 👍🏻
All the best.
Paul
Message 3 of 13
Great thank you 🙂
Willow27
Message 4 of 13
Thanks - will do 👍🏻
Message 5 of 13
Hi Paul,
That's no problem.  Monitor over the next couple of weeks, and any issues, just get back to us here 🙂
Willow27
Message 6 of 13
Hi Karl,
Yes I did do a reset of the DVA and no drop outs since then.
However, due to the random nature of the previous connection drop outs, I feel that two days with only about 3 calls made, is too soon to say if the problem is cured or not.
I will be more confident in about a fortnight I feel.
Hope that’s ok.
Paul.
Message 7 of 13
Did you try the reset and did this help ?
Message 8 of 13
Yes of course, just post back here. If it is still happening following this then the next step would be to replace the DVA to rule this out. Please let us know how you get on.
Message 9 of 13
Incidentally - the Grandstream DVA is reporting no issues as all the lights are solid blue.
However, I’ll still do a factory reset on it as per the instructions.
Ta
Paul.
Willow27
Message 10 of 13
Thanks Michelle.
I have done a factory reset before - but some time ago now. So I’m going to do another one and see how things go and report back.
Because of the random nature of the drop outs, I won’t be sure of the result until after a few phone calls - so I won’t be reporting back for maybe a few days.
I’m hoping that will be ok and I can just report back here with the results?
Message 11 of 13
Hi Willow,
How are you getting on? Did resetting the DVA work?
Message 12 of 13
Hi @Willow27
Thanks for creating a new topic. Have you tried factory resetting the Digital Voice Adapter?
Resetting your Digital voice adapter
If your Digital Voice adapter or router has stopped working, we may ask you to reset it to check everything's working as intended. To do this:
Insert a pin or straightened paper clip into the hole labelled “Reset” on your Digital Voice adapter.
Slightly push and hold it in for up to 20 seconds; or until all the lights, apart from the power light, switch off. Once this happens release the reset button.
Factory reset of the device will take a full 15 minutes and you need to wait until the allotted time has passed for the full factory reset to be completed. After 15 minutes, check your Digital Voice adapter device and try to re-test to check if the issue resolved.
