on 08-01-2024 10:42 AM
Our voip home telephone disconnects itself. I have changed the handset to no avail.
on 08-01-2024 03:10 PM
Hi Graham,
If you have the wifi hub 2 then your telephone plugs directly into the router, you don't need to use the digital voice adapter. Is your telephone currently connected to the green telephone port on the router?
on 08-01-2024 01:52 PM
Michele,
set up guide heading 'know your wi fihub 2 and there’s also a 'digital voice adaptor'
on 08-01-2024 10:49 AM
Hi Graham,
I'm sorry to hear this. Can I just confirm, do you have the Wifi Hub 2 or the eero with the Digital Voice Adapter please?
