Home Phone
noise on line
Ramsbottom8
Message 4 of 4
My landline phone makes a continuous buzzing sound when you lift the receiver. If you dial it from another phone it just buzzes and crackles.
3 REPLIES 3
Message 1 of 4
Hi @Ramsbottom8
Do you still need our assistance with this?
Message 2 of 4
Hi @Ramsbottom8
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Message 3 of 4
Please try temporarily moving this handset to the test socket behind the Master Socket's removable faceplate, with a new or known good microfilter. If it is still no good there, does the phone take batteries & have they been changed? Do you have another handset that you could try in place of it?
