Get answers and information about our security products.
on 29-11-2023 04:37 PM
Hello can someone help me update the firmware on my HG633 my hardware version is H1.01 and my current firmware is V2.00t is there a more current firmware version available.?
on 05-12-2023 09:23 AM
Hi Talkinfox
on 01-12-2023 03:23 PM
You're Welcome 🙂
on 01-12-2023 03:22 PM
Thanks 👍
on 01-12-2023 03:12 PM
WiFi Hub ordered for you.
on 01-12-2023 03:01 PM
If it’s a free router yes a new sagemcom router would be good plz. Thanks.
on 30-11-2023 01:53 PM
Hi Talkinfox
Would you like me to send you a new router? This would be a Sagemcom WIFI hub.
on 30-11-2023 01:15 PM
Thanks I’ve turned off remote access. I Think it’s time to invest in a much better third party router my talk talk router is pretty simple and old and with it not being supported by manufacturer anymore makes sense to have a better spec mainstream router that can be configured to work with other IPS’s. 👍
on 30-11-2023 12:28 PM
As far as I'm aware there are no plans for a new firmware version at the moment but that's not to say that there won't be at some time in the future
30-11-2023 12:20 PM - edited 30-11-2023 12:29 PM
Well I thank you and the talk talk community support team again for verifying that my firmware is uptodate that essentially all I needed to know you gave me a prompt answer something the talk talk technical department over the phone was unable to do after being put on hold for many minutes. One more question the HG633 router is discontinued and not supported by the manufacturer does that mean in general there will be no more firmware updates for that model? Because in that case turning off remote access is the most sensible thing to do since it poses a big router security risk for nothing?
on 30-11-2023 11:57 AM
Hi Talkinfox,
We do update our router firmware automatically and in the vast majority of cases this works fine but occasionally the automatic update doesn't go through. We don't supply the firmware as a file to be downloaded and manually installed by the customer but we can usually manually update the firmware remotely if the automatic update doesn't work.
30-11-2023 11:40 AM - edited 30-11-2023 12:01 PM
That’s good to hear because when I phoned up the talk talk technical department over the phone they couldn’t even verify that my current firmware was uptodate after many minutes of being put on hold all the could say is my router gets automatically updated, the problem with that is that isn’t really true last time i updated my router I downloaded the firmware file from hauewi unfortunately hauwei do not support the HG633 anymore. My point is my firmware wasn’t updated by remote acesss I had to install it via file by manufacturers download…. Could the fact that Hauewi not supporting the HG633 router anymore be the reason why talk talk technical department being so vague not verifying current firmware and that it’s automatically updated be mostly to do with customer then demanding a supported router instead.
on 30-11-2023 08:18 AM
Hi Talkinfox
I've checked and your router has the latest firmware version - 2.00.
on 29-11-2023 06:17 PM
Leave it on all the time for now - staff will be back on here during the day tomorrow, @Talkinfox.
29-11-2023 04:58 PM - edited 29-11-2023 06:08 PM
Profile updated router is switched on.
on 29-11-2023 04:51 PM
Thanks for starting your own thread, @Talkinfox.
Please also follow the steps posted here, so staff can identify your account:
https://community.talktalk.co.uk/t5/Broadband/HG633-firmware/td-p/2932328#M859717
The main thing to then do is simply leave the router switched on until staff confirm the update.
