on 25-11-2023 05:35 PM
Is it possible to actually disable the PIN requirement completely?
During the initial set-up it is required that a 4 digit PIN is entered, I have no need for a PIN in my house.
I have looked for the option to be able to not require its use but all I can find through the set-up menus is to be able to change it for a different 4 digit PIN.
Does anyone know whether it is possible or not? its not a big problem but just an annoying niggle occasionally.
on 27-11-2023 07:51 AM
It's not possible to fully disable the pin. Sky will often show some movies that are age restricted, early in the morning, so this will force a pin requirement if you are subscribed to Sky Cinema via apps such as Now TV.
