4K box set up
Dave63
Message 6 of 6
In setting up a new 4K tv box, after carefully making all the connections, the instructions told me to press the button marked Source on the remote control provided. My remote control does not have a button marked Source and does not match the illustration shown on the remote used in the set up instructions.
Can anyone please tell me how to proceed.
5 REPLIES 5
Message 1 of 6
There is a source button on the remote for the TV HUB, but no source button on the 4K TV Remote.
The source button can be found on the TV Remote itself and is just to make sure your TV is on the correct HDMI source channel for the TV Box.
Message 2 of 6
Don’t worry. Thanks for your help anyway.
Message 3 of 6
Hi @Dave63 sorry then my knowledge is exhausted(not difficult)
I think my colleague who could help is on holiday so unless others with deeper knowledge are around it'll be Monday before the excellent TT staff are in then they will get you sorted quickly.
Sorry not to be more help
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
Dave63
Message 4 of 6
I think so. Instructions refer to it as remote control.
Divsec
Message 5 of 6
Hi @Dave63 do they mean source on your TV zapper?
