4kbox will not record bbc tv programmes
Bazzy1
Message 2 of 2
My 4k box will not record BBC programmes when I am watching another channel. Also it will not record another channel when watching BBC programmes.
1 REPLY 1
Message 1 of 2
You cannot record a channel whilst watching another as the box only has 1 tuner.
If you wish to view a channel whilst recording you will need a separate aerial feed to your TV. To do this you will need to buy a cable splitter and run a cable from this to the box and one to the TV.
These can be purchased on line, supermarkets or local TV store.
