Adding apps
Jessicahannah
Message 5 of 5
Can you add apps onto the tv i wanted to add discovery plus as i already have the subscription amazon wont let me sign in they want me to buy it again
4 REPLIES 4
Message 1 of 5
Hi @Jessicahannah
If you have the NETGEM 4k TV Box then Discovery+ is not available and apps cannot be added to this box.
If you have the TalkTalk 4K TV HUB, the android based one, then apps can be added to this and Discovery+ is available.
Some Smart TV's do have the option to add apps, and you can check if your TV has this option.
Message 2 of 5
OK, you say TV, is that what you mean, or a TalkTalk TV Hub? If the latter, then you should be able to download additional apps via the Google Play store. If it is the TV itself, then it depends on which apps the manufacturer supports.
Jessicahannah
Message 3 of 5
I havent brought it via amazon that is what im saying i have brought it seperate but the only way i can see to add it on this tv is via amazon !
Message 4 of 5
If you have discovery+ via Amazon then you need to access it that way.
