BBC iplayer uhd buffers on talk talk 4k box
SmC40
Sightseer
Message 12 of 12
Bbc iplayer uhd buffers on my talk talk 4k box , HD is ok just UHD problematic  . All other apps UHD such  as netflix play  ok , has anyone else had this problem
11 REPLIES 11
Message 1 of 12
I've requested a TV box is sent to you.
Message 2 of 12
Yes as long as 4K I don't mind , just looking to resolve the problem , much appreciated
Message 3 of 12
I can swap out the box, but TalkTalk no longer provide the Netgem box, so would have to substitute the Android TV Hub.
Would you like to try that?
Message 4 of 12
Yes I have tried both WiFi and ethernet cable , have same problem on both
Message 5 of 12
Is the box connected over Wi-Fi ?  Have you tried with a wired connection to rule out a Wi-Fi issue etc.
Message 6 of 12
Hi I have reset box and still same problem , and to make matters worse has also started to do buffer on itvx on all formats ....not sure if box is faulty?
Message 7 of 12
No Problem 🙂
Message 8 of 12
Ok I will try this tonight and advise tomorrow thankyou
Message 9 of 12
OK, next option is to reset the box.  Press the button on the side 5 times to initiate a reset.  This will reset the box and reinstall the software and apps.
Message 10 of 12
Hi I have reset the router and the box still the same problem , iplayer uhd works OK on other platforms including smart tv Sony bravia 4k that box plugged into
Message 11 of 12
No issues with your line or sync speed, that's about 77mb.
Have you tried powering off the router for 30 minutes to reset the session to see if this helps.
If still failing, it could be an issue with the app itself.  Have you also tested on another devices, laptop or tablet etc.
