Bad signal on TV box
Davidmatt
Message 6 of 6
Hello
We keep getting a bad signal message  on our TV box intermittently and freezing of the picture. However if I attach the arial straight to the TV there are no issues. I spent an hour on the phone to support without any success.
5 REPLIES 5
Message 1 of 6
OK, keep an eye on things.  If it starts to happen again, try a box reset.  Press the button on the side 5 times to initiate a factory reset of the box.
Message 2 of 6
Hi Karl
Yes we have retuned and there are no splitters. The box kept freezing yesterday. I unplugged the aerial and plugged directly into TV and this was fine. The box is working ok today though. Not sure it's when the box has been on for a longer time?
Message 3 of 6
Have you tried retuning the channels on the box, did this change anything?
Do you have a single aerial cable going to the box, or do you have any splitters in place ?
Davidmatt
Message 4 of 6
Hi Karl
It's a netgem N7950-T2C-8-AB2
David Matthewson
Message 5 of 6
What Model TV box do you have ?
Anonymous User
