Free view channels missing
Janelesg
Message 5 of 5
I’ve moved my TV to a different location in my lounge. I’ve bought a new cable for the aerial socket but I have limited free view channels now.
4 REPLIES 4
Message 1 of 5
Hi Jane,
How are you getting on?
Message 2 of 5
Hi @Janelesg that's an odd one, if your channels have disappeared from the TV when plugged directly to the aerial it does point to something outside of Talktalk, I'm wondering if your local transmitter is having temporary issues?
This link might help https://www.bbc.co.uk/reception/check-for-transmitter-faults/#/undefined
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
Janelesg
Message 3 of 5
I’ve plugged it into both and retuned… no joy.
Divsec
Message 4 of 5
Hi @Janelesg Is your aerial plugged into the TV or the set top box? Have you tried retuning both?
