Freeview box not working
Nicolas2
Message 5 of 5
Our freeview box has suddenly stopped working, we have sound but no picture.
It is quite old, is it possible to request a replacement box please?
4 REPLIES 4
Message 1 of 5
TalkTalk stopped providing the legacy Youview box models 3 years ago, so this box cannot be repaired or replaced.
You may be eligible for the new 4K TV Hub.  If out of contract you will need to renew.  Also, any previous TV charge is removed and now replaced with TalkTalk Entertainment at £5 per month to cover the box rental and additional content or offers via My Account.
If you give our Teams a call to request the new TV Hub, they can discuss the latest offers with you.
Nicolas2
Message 2 of 5
  • Hi Karl,
  • We have tried resets and just have a blank screen. Would it be possible to request a new box please? Thanks.
Message 3 of 5
Hi Nicolas,
Did you try the resets as advised, did this help ?
Message 4 of 5
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
TalkTalk now only supply non-recordable boxes, So it's best to try all alternatives if recording is important to you.
You will need to phone and probably recontract to obtain a new box.
Hope it works and please let us know how you get on.
