How can I find out what my PIN number
Poppylilly123
Message 3 of 3
Trying to find pin so I can access mytv
Message 1 of 3
Hi @Poppylilly123
Did the advice from my colleague help.
Message 2 of 3
You shouldn't need one to access my TV, but may to access a particular programme or app if you have age restriction turned on
Box default is 1234. You could try 0000 if that does not work but if you set a pin during setup you will need to reset your box to rectify this.
You can turn off ages restriction in your settings.
